194 burnouts..a little help please. - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #11 of 22 (permalink) Old 11-15-2006, 07:31 PM
While we're on the subject... Is it just me or getting PURE WHITE led's not easy... i'd say at least half of the 14 I ordered had a pretty strong purple tint to them... while some were a nice white color like I wanted...
PerfectXtreme is offline
post #12 of 22 (permalink) Old 11-15-2006, 07:52 PM
HighSpeed6's Avatar
Send a message via AIM to HighSpeed6 Send a message via Skype™ to HighSpeed6
djquik how are your LEDs holding up? Any chance we can get that picture?
|206HP| |204TQ|
HighSpeed6 is offline
post #13 of 22 (permalink) Old 11-17-2006, 06:12 PM
djquik1's Avatar
Groans: 14
Groaned at 9 Times in 6 Posts
I have spaced it off completely.You want a close up daytime pic.They are holding up just fine and are very bright.I will get one taken tomorrow.sorry guys.
2010 F-150
1990 F-150
djquik1 is offline
post #14 of 22 (permalink) Old 11-17-2006, 06:29 PM
DennisW's Avatar
Quoted: 11 Post(s)
Is there any LED that works inside the day time running light that will not burn out? [/b]
i believe if you read the warnings from most 194 LED bulb distributors, they warn against using them in applications like the sealed headlight assembly because of the heat generated by the headlamp bulbs. that's why your bulbs are burning out so quickly
DennisW is offline
post #15 of 22 (permalink) Old 11-17-2006, 06:41 PM
djquik1's Avatar
Groans: 14
the thread is now about the 194 supernova bulbs that have a heatsink for higher heat applications.
2010 F-150
1990 F-150
djquik1 is offline
post #16 of 22 (permalink) Old 11-19-2006, 01:55 PM
djquik1's Avatar
Groans: 14
here is a daytime pic of the bulb,as you can see i had to notch the sides of the heatsink to get it in there
2010 F-150
1990 F-150
djquik1 is offline
post #17 of 22 (permalink) Old 01-05-2007, 05:14 PM
Optik 6i's Avatar
Send a message via AIM to Optik 6i
autolumination.com under the 194 section,i think they are the second ones as you scroll down.They do require modification to fit in the housing,pm me and i will give you details
Hey I just posted in the other 194 topic. I bought the Supernova's now I need to figure out how to get them to fit in. How did you get them to fit the housing? What did you use to notch the heat shield?
2007 Black on Black MS6 GT w/ Sirus & Moon Roof, 25% Tints (Supernova DRL's, Matrix 194's door lights)
2003 Steel Grey on Black GT w/ Moon Roof 15% Tints (Sold)
Optik 6i is offline
post #18 of 22 (permalink) Old 01-05-2007, 05:21 PM
djquik1's Avatar
Groans: 14
pm me and i will give you my number and explain how i did it.I had one fail on me from a voltage spike.
2010 F-150
1990 F-150
djquik1 is offline
post #19 of 22 (permalink) Old 01-05-2007, 06:06 PM
HighSpeed6's Avatar
A "voltage spike" due to heat in the headlight housing, or something different?
|206HP| |204TQ|
post #20 of 22 (permalink) Old 01-05-2007, 06:15 PM
djquik1's Avatar
Groans: 14
I still had one functional and after talking to the guy from supelumination,I found out that you can destroy leds if they are on when you start the car.I figured if i had one burned out i might as well test the theory.Sure enough,i had my drl's on when i turned it over and it started strobing almost instantly,it failed within 20 minutes.So i can confirm that a voltage spike killed it.
2010 F-150
1990 F-150
djquik1 is offline
