The LED tail-lights - Page 13 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #121 of 148 (permalink) Old 01-28-2007, 01:52 AM
HighSpeed6's Avatar
Send a message via AIM to HighSpeed6 Send a message via Skype™ to HighSpeed6
They look great! Wish I could get my hands on some quality Black Euros.
|206HP| |204TQ|
HighSpeed6 is offline
post #122 of 148 (permalink) Old 01-28-2007, 11:13 AM
Here is one pic I just took. I installed these on Wednesday. The install was totally easy. The only difference between these and any other lights is that you have 2 wires coming out of each inner light piece instead of plug. However, the wires have special tips so all you do is plug the wires into the terminals on the pigtail. I am extremely pleased with these lights so far. I just took a 300 mile trip today in 20-30 degree temps to see family and the lights performed flawlessly.
Sorry the car is dirty but you have to expect that in winter in the midwest:[/b]
Are the inner lights super flux (square) too? And do the inner lights light up with the brake lights?
Do we have a pic of the white LED reverse lights yet?
Justins6s is offline
post #123 of 148 (permalink) Old 01-28-2007, 11:21 AM
Do we have a pic of the white LED reverse lights yet?[/b]
Yes, they are all superflux. No, I don't have it set up for the inner lights to light up with the brakes. I believe it is entirely possible to do so. You would have to do the brake light mod. According to Kevin, there is a third wire in the inner LEDs to make it light up at the high brightness level. So it should be as easy as tapping into the brake + from either the LED trunk stop light or outer tail light, run the wiring and connect to this third wire.
Indy MPS6 is offline
post #124 of 148 (permalink) Old 01-28-2007, 12:04 PM
Yes, they are all superflux. No, I don't have it set up for the inner lights to light up with the brakes. I believe it is entirely possible to do so. You would have to do the brake light mod. According to Kevin, there is a third wire in the inner LEDs to make it light up at the high brightness level. So it should be as easy as tapping into the brake + from either the LED trunk stop light or outer tail light, run the wiring and connect to this third wire.[/b]
Nice sounds good
post #125 of 148 (permalink) Old 01-28-2007, 01:05 PM
post #126 of 148 (permalink) Old 01-31-2007, 10:53 AM
djquik1's Avatar
Groans: 14
Groaned at 9 Times in 6 Posts
emailed a few questions to car-leds.com.
waiting for reply,then ready to purchase based upon answers.
2010 F-150
1990 F-150
djquik1 is offline
post #127 of 148 (permalink) Old 02-04-2007, 04:29 PM
hey all, seems that all mention of relacing the stock flasher unit with one for use with led turn signals has dwindled off.Has anybody found (and if so installed) one of these flashers for the 6??
Tungsten Grey 2006 Mazda 6S Sport: ATX (w/Tip-Tronic), 6-Disc Changer w/ Bose, Moonroof, All Weather Mats
-Current Modz -
MazdaSpeed CAI, Eyelids, VG Sharkfin Antenna, Clear side markers, Interior LEDs, Chrome Dome Rear Turns, Silverstar Front Turns
-In Boxes,Not Yet Installed-
NRG Hood Dampers, Moonroof Deflector, Rain Guards
-Future Modz-
Injen Cat-back + HIDs (For now)
06 Mazda Sicks is offline
post #128 of 148 (permalink) Old 02-04-2007, 05:38 PM
djquik1's Avatar
Groans: 14
If these are done properly,we wouldn't need to change flashers since these would have resistors already in line for it to be a plug-n-play design.
2010 F-150
1990 F-150
djquik1 is offline
post #129 of 148 (permalink) Old 02-04-2007, 10:16 PM
Hello all,
If you use a special flasher to keep the regular blinking frequency, you will not need to worry about the heat and temperature of the resistor , it is good; but it will not remind you in case the head blinking bulb is broken. so you need to check it yourself often.
PS:There is still some problem with the led board, hopefully the new edition will be available within 10 weeks.
car-led.com is offline
post #130 of 148 (permalink) Old 02-04-2007, 11:58 PM
Hello all,
PS:There is still some problem with the led board, hopefully the new edition will be available within 10 weeks.[/b]
Yea, What i'm looking for is the special flasher for a non-speed 6 so i wouldnt need the resistors...But last i heard there were none available....anyone know if these flashers are around yet? this may not be the right place for this question, but it's the only good thread that mentioned it at one point.I thought someone here might know.thanks
-Current Modz -
-Future Modz-
