HID with Factory Projectors - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 9 (permalink) Old 10-17-2006, 04:49 PM Thread Starter
Hoho's Avatar
Send a message via AIM to Hoho
as title and description says.
(HID with Factory Projectors, will bending the cut off shield add the blue flicker to the cut off?)
so bending the cut off shield helps bring the blue color at the cut off, on the retro'd projectors.
will this do the trick for factory projectors? or will it just blur the white/yellow cut off.
and this is with a aftermarket 5000k kit
2003 Mazda6 S V6 soon to be 3.5L
Injen CAI / CPE MAF Customizer for Injen / Optimized TB / MSDS Headers / A'PEXi WS2 Catback Exhaust / Kenstyle Front and Sides / ViS CF Hood / Eibach Pro Kit 1.5/1.4 Lowering Springs / Work VS-XX 3-Piece Wheels
Coming soon: big bore motor, diamond pistons, k1 rods, awr mounts, brembo gt bbk, ground control suspension, autoexe rear strut brace, racingbeat rear sway bar.
Hoho is offline
post #2 of 9 (permalink) Old 10-17-2006, 06:33 PM
On kits, the light is the color that OEM HID cut offs have.
Mazda 6s GT is offline
post #3 of 9 (permalink) Old 10-18-2006, 12:14 AM
I think the cut off shield on the factory projectors only reflects light upward to light up road signs, but also blinds people if you don't take it out.
'16 CX-9 Touring
'04 6s MTX
Mods: Yes.
8/8/17:
trickdout6 is offline
post #4 of 9 (permalink) Old 10-18-2006, 02:38 AM Thread Starter
Hoho's Avatar
nah im refering to the cut off shield that's in all projector headlamps, not the up-beam plate which i removed already. =)
Hoho is offline
post #5 of 9 (permalink) Old 10-18-2006, 02:42 AM
t_mo_t's Avatar
hmm interesting.... i believe it would produce a bluer cutoff... i've tested with our H3 bosch mini fog proj and it worked really good... so i believe if you try to bend ~1mm towards the bulbs, you'll get a li'll bit bluer cutoff... NOT 100% SURE... but you can try it if you want.. lol ... but it's hard to get the shield bent evenly, as it's a mounting hole for H1, which is much smaller than D2S, when i tried to bend my fog's shield, i had the headlight apart, so i could bend it from front... if you try using a hook, u'd prob mess up the cutoff as the center part of the shield would bend more than the sides, which will give u uneven cover for the proper cutoff...
but the thing is, our H3 prj is made by bosch, and i dont know which company made our halogen proj...
why dont u become our test rat and let us know the outcome??lol..
if you bend the shield too much, it will surely become blur-er and glare the oncoming traffic MORE....
EDIT: check this out 8th pic down...
http://forum.mazda6club.com/index.php?show...c=51790&hl=
t_mo_t is offline
post #6 of 9 (permalink) Old 10-18-2006, 02:53 AM Thread Starter
Hoho's Avatar
hm... thx for the heads up, i just installed the kit today (on a seperate thread)
ya looking at how i'd have to do it with the headlights closed, it's gonna be hard, as i opened the headlights twice before already, i do not wanna tamper with the silicon and reseal AGAIN.
i'll see what i can do, but im probably gonna lay off bending it for now. i would love to be the test rat and let u guys know if i can do it tho
Hoho is offline
post #7 of 9 (permalink) Old 10-18-2006, 02:54 AM
t_mo_t's Avatar
lol i c.. and yeah... i've tried to mod my bosch h3 and it really did work... it has blue cutoff now.. and i m using stock halogen bulbs btw...
t_mo_t is offline
post #8 of 9 (permalink) Old 10-18-2006, 02:59 AM Thread Starter
Hoho's Avatar
hm... that's pretty cool, would u happen to have the link to the how to? (unless it was mentioned in the thread u posted xD)
Hoho is offline
post #9 of 9 (permalink) Old 10-18-2006, 03:08 AM
t_mo_t's Avatar
it;s just bending the shield... i used my fingers, as i had the headlight apart... but if yours closed, you can and use a cloth hanger with styrofoam at the edge(to prevent scratching).... like i said, maybe u'll get uneven cutoff if you bent it in the middle instead of balancing it... but it's a rare case anyway...
t_mo_t is offline
