Trying to figure out a problem. - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 15 (permalink) Old 10-05-2006, 10:29 PM Thread Starter
Send a message via AIM to warpedexistence
A couple days ago i did the headlight tinting mod as outlined on the 6tech website. It came out great, everything looks spectacular. Tonight when i got out of class it was pouring. So i get to my car and about halfway home i notice that one of my headlights is out. I had my headlights on during my trip to school but wasn't really paying attention as to if they were both on or not. All the other lights in that housing are fine (hi-beam, parking, and turn signal) and there doesn't seem to be any water accumulation in the housing it's self. Did my bulb just burn out? Or could my sealing of the housing be faulty and the rain has cause the bulb to malfunction? I have crappy bulbs in it, which will remain nameless, and i really wasn't expecting much as far as life span. I did however replace all the bulbs at the same time so it would be a bit odd for only one to wear out from normal use. Any ideas?
SHIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII IIIIIIIIIIIIIIIIIIIIIIIIIIIIT
warpedexistence is offline
post #2 of 15 (permalink) Old 10-05-2006, 10:59 PM
1) Replacing bulbs with those wanna be ultra super bright white bulbs are horrible...though they do increase output by like .2% it doesnt make sense to keep replacing them.
2) It could also be the fuse. Take look under the fuse bux under the hood and check to see if you blew a fuse.
3) If the fuses are good than try swapping the bulb from one headlight to the other....
other than that i dont know what to tell you bud, except post some pics of your new smoked out housing!
FS:
sexy6s is offline
post #3 of 15 (permalink) Old 10-05-2006, 11:29 PM Thread Starter
Thanks for the response. Tomorrow i'll check everything out. I had bought the bulbs and installed them before i even found this website. It was actually the reason i looked for this website. Mazda wanted $75 dollars in labor to change one bulb, i ended up getting a shop to do it and having to shell out 210 for all 4. I know i know i got shafted but with out this site as a resource and the only instructions being "consult a mazda certified technician" in the manual, i wasn't sure what other options i had. So i claim ignorance about the poor quality of the bulbs.
Here are the pics of the housings, nothing close cause it just looks black anyway.
http://forum.mazda6club.com/index.php?showtopic=61143
post #4 of 15 (permalink) Old 10-06-2006, 09:53 AM
looks good and i'll have to admit debears2k is right...def. need a appearance package lol
the rims look nice to by the way...gotta love those RX8's
it realy is easy to get to the bulbs and replace them yourself...use the guides in the sticky..i'm going to say most likely its just that a bulb blew probably...
FS:
sexy6s is offline
post #5 of 15 (permalink) Old 10-06-2006, 10:12 AM
If it is water getting into the housing and causes the light to malfunction as you put it. Pay attention the next day in the morning see if water vapor built up inside the light housing as this should be the indication if water does get in. If it is clear, then more than likely your light bulb blew coinicidently.
M6Gr8 is offline
post #6 of 15 (permalink) Old 10-06-2006, 11:45 AM Thread Starter
It's still raining so i guess i'm stuck with my fathers A4 for the day. There is no water vapor or water accumulation in the headlight even after a night of rain so i think i'm golden on the sealing. I'll check it all when it clears up. I should probably get HID's soon.
post #7 of 15 (permalink) Old 10-06-2006, 11:58 AM
duhh you shoulda just done a Retro while you were in there painting! lol
agreed if there's not condensation which is what i was super scared of while doing the retro than you're more than likely just going to need to replace the bulb. what brand was it if you dont mind me askin, theres alot of people on here that replace silverstar and sylvia bulbs and what not all the time.
My one buddy who has a camry gets new bulbs off e-bay once a month!
FS:
sexy6s is offline
post #8 of 15 (permalink) Old 10-06-2006, 03:56 PM Thread Starter
Haha it's silverstar, i'm just going to replace them with stock ones. I don't want to pay for more of these bulbs.
post #9 of 15 (permalink) Old 10-07-2006, 03:43 AM
t_mo_t's Avatar
btw, any of the bulbs in the headlight turned on when you did that? not that it's impossible, it's probably when u bake the headlight, one of the wires got fried.......... NOT 100% sure though... which light doesnt turn on?
t_mo_t is offline
post #10 of 15 (permalink) Old 10-07-2006, 04:14 AM Thread Starter
Every bulb in the drivers side housing(the one with the faulty bulb) worked after the bake. The low-beam H1 is the one that has gone out. If the rain ever freaking stops i'll take care of it. I just think it would be odd for only one bulb in the housing to go if water was getting in there and i want to run it past others to see if someone with more knowledge might be able to shed some light on it. Thanks guys.
