Alternator upgrade or leave it alone - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #11 of 11 (permalink) Old 10-10-2006, 01:19 AM
Send a message via AIM to bumpin_blazer
2 things on the RMS is 1) unless you've got an amp rated at 12v or you've got an amazing electrical system, you won't get RMS if it's rated at 14v. 2) the stock alt in the 6 cylinder 6 is what 105-120amp? Figure the max load it can do while the car is above idle is that 120 amps of which the car takes 20-35 depending on what's running. So that leaves you with 80-90 amps for a system. 1kw amps take over 90amps to produce that kind of power if you really want it.
my thought, is what kind of amps are you running before you say you're running 2kw of power what is it going to be? i've built 4 systems that have competed and won world title's or records in the past 3 years so I can try and help. anyone running a lot of power and saying they have no issues with stock or even an added battery or a cap is an idiot. caps any and all, are a bandaid not a fix. a cap has to recieve an electrical charge in order to help your system, if you're already needing more juice than the main source(alternator) an supply it just takes more energy to get the cap working right.
2006 6s Bright Island Blue:
Stock options- bose/moonroof/power seat, homelink mirror
My Goodies added: debadged, 8000K 55w HID Low beams 8000K 55w lower fogs, DDE Raptor Angel Eyes, PIAA Spark 8000K H1(high beams), tail-light mod VG Sharkfin Antenna, Accolade Sport Grill, LED Rear Reflectors and Side Markers, LED rear tail lights RB Rear Sway bar, MS Springs and shocks, and B&M 70264 Transmission Cooler. ADR Cypher 18x7.5s wrapped in General Exclaim UHP's.
Soon to come- Sniper tuner, headers then finish the exhaust.
bumpin_blazer is offline
