LED bulbs for my MS6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 2 (permalink) Old 08-27-2006, 10:11 AM Thread Starter
daztd's Avatar
Quoted: 35 Post(s)
I have a 2006 MS6 and I wanted to put LED light bulbs on it. I had a 1994 Ford Probe GT in which I put LED bulbs in it. The MS6 uses different LED bulbs then my Probe did. Well, here are some pics of them.
The best place to buy the LED bulbs is from Ebay from:
Velocity LED's
or from this person, but the bulbs come from Hong Kong. 5-7 days to get them but well worth it!!
Warden-jp2002LED's
Buying from Warden-jp2002 is probably the best place to get them. Great prices and awesome products.
[attachmentid=15339]
The driver side has the LED's. It's a much deeper red compared to the other side being a red orange color
[attachmentid=15337]
The pass. side has the 1W Flat white LED bulb
[attachmentid=15338]
Here's a pic of it.
[attachmentid=15340]
Marker lights on without the HID's on.
[attachmentid=15341]
It's hard to see the LED bulb in the housing, but it's there.
[attachmentid=15342]
A different angle
[attachmentid=15343]
Check out the wall with the parking lights on. Wow, what a color difference!!
ID:	49438   Click image for larger version
ID:	49439   Click image for larger version
ID:	49440   Click image for larger version
ID:	49441   Click image for larger version
ID:	49443   Click image for larger version
2006 MazdaSpeed 6 Grand Touring | Velocity Red Mica
DashHawk, CS TIP/SRI/TMIC, SU MM, JB EGR block plate/plug/TB TIG, CPE RDM, Perrin EBCS, Turbosmart BPV,TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, silicone boost tubes, Bilstein HD, LED bulbs, TRS projectors, HID fogs, Hawks pads, Amsoil diff/pto/trans, navi, XCarLink USB
daztd is offline
post #2 of 2 (permalink) Old 08-27-2006, 10:25 AM Thread Starter
daztd's Avatar
Quoted: 35 Post(s)
Cool
These are the bulbs I have in the tail lights and the 194 LED bulbs I used
[attachmentid=15344]
The color output is on the blue-er side then pure white. This bulb is used on the front headlight house(High beams)
[attachmentid=15345]
This bulbs is used in the licence plates lights. The color is more pure white. I may switch them with to go to the front headlight and have the 1W LED's in the back licence plates.
[attachmentid=15346]
These are the bulbs used in the tailights. The brightness is the same, but color is a deeper red. Regular bulbs produce a red-orange color output. The good thing about LED's is that they consume very little power, instant on and instant off (great for you brake lights so people won't hit your MazdaSpeed 6 or regular 6) and the bulb last 10yrs on average. Plus, it gives your car a different look!! I hope this helps anyone. If you have questions, just ask! Tony
ID:	49445   Click image for larger version
ID:	49446   Click image for larger version
daztd is offline
