Boost Gauge Help - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 2 (permalink) Old 08-21-2006, 05:42 PM Thread Starter
Just looking for a wiring diagram as for what I need to find under the dash to get the proper 12v source etc. Thanks.
I'm going to change my question, as I have actually figured out the power source issue. I really only need to know where I have to or can install the Vac line Tee to get the boost reading from the turbo, on the gauge. I have looked at "onedeath's" pictures, but cannot see anything that matches under my hood? Thanks.
Danstona is offline
post #2 of 2 (permalink) Old 08-26-2006, 07:36 PM
ryceboi's Avatar
tap into the vacuum line going into the bypass valve, which is on the front right of the engine, attached to the hardpipe coming from the IC and heading to the throttle body. search in the mazdaspeed section and you'll find tons of stuff to help u out.
ryceboi is offline
