Lighting Questions... All-in-one - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 2 (permalink) Old 05-27-2006, 11:15 PM Thread Starter
BIG FIRST QUESTION!!!!!!
Are the headlights for the 2 standard 6 models... and the speed6 the same? Same bulbs... same housing.. same parts? Are the Mazda 3's housing and bulbs the same?
From what I can tell (don't have my car here with me now... and i keep forgetting to go look at night)... but the Speed6 (and all mazdas now)... come with the following:
1) Bright standard bulb parking lights... Gives a "halo" effect sorta as the bult is off centered and reflects around the inside
2) HID Low Beam... Just about as good as you could buy or want on a car I thik...
3) Standard Halogen high beam... Same light you get from any vehicle these days....
4) Breaklights are all standard bults you see anywhere... And corner lights as well...
My Questions are.... (Numbered to go with above statements)
1) Has anyone replaced this tiny "pretend halo" bulb with a different bright white / blue bulb... and noticed an improvement in looks?
Has anyone installed the Halo kit for the 6... And if so, how did the install go? How bright are they? Do they burn out? If so can they be fixed/replaced w/o melting entire headlight into parts again?
2) I'm pretty sure there are no mods.. or changes to this HID setup... that would provide any improvement.. but if so.. please post about them...
3) Standard Halogen high beam... Are there HID upgrades / replacements for this? Are they actually bright? Or same as the low beams? Whats the price tag on these kits if they exist... I know HID kits for hondas and such.. the TRUE HID kits.. are SUPER spendy...
4) As the bulbs are reflected through plastic.. no matter what you use... it won't have much of an effect on the looks... but if anyone has seen lighting mods inside the tail light housings... please post about them...
PerfectXtreme is offline
post #2 of 2 (permalink) Old 05-28-2006, 03:23 AM
t_mo_t's Avatar
1) i dont know if the US's MS6/06 mazda6 has DRL(Daytime Running Lights), but here in Canada, they've switched their DRL to highbeam instead of lowbeam... so that's not really HALO or bright parking light... but if u want to install a DDE, get this
http://forum.mazda6club.com/index.php?showtopic=49868
2) the brightness of OEM HID(Xenon) depends on the car itself... how the headlight is designed and everything, the OEM Bosch E46/Audi TT Projector are very reliable in term of size and output... for better output, there are many other projectors, but retrofitting other projectors would waste lots of time and not worth it if u have the OEM HID.... but if u like different route, check this..
http://forum.mazda6club.com/index.php?showtopic=43308
3) It&#39;s useless to change ur high beam to HID... first of all, since u r going to flash ur highbeam, it&#39;s bad for the ballast !! rule of thumb, never flash ur HID or never turn on/off ur ballast 3times/hour... secondly, if u have the 06/MS6 HID option, it&#39;s bad for the HID kit to turn on with the DRL(less wattage to the ballast/bulb) <- not too sure about how the HID option works on the 06/MS6
4) http://forum.mazda6club.com/index.php?showtopic=45486
t_mo_t is offline
