auto up/down stopped working drivers side window - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 9 (permalink) Old 04-25-2006, 01:24 PM Thread Starter
broken08's Avatar
Send a message via AIM to broken08
my 06 6i has auto up/down on both front windows. it also has the feature where you hold down the unlock button on the remote and they roll down. currnetly the remote feature doesn't work, and the auto on the drivers window doesn't work though i can still manually move it, but the passenger side still works normal from the drivers switch set.
now i just installed some after market speakers in the front doors, so i'm going to assume there is some correlation between the two events. I painstakingly rechecked all the connections and everything is fine.
any thoughts?
I don't want to go in for warrenty because we all know exactly what they will say.
-Sean
2006 Tungsten gray 6i mtx base
Racingbeat springs, Racingbeat sway bars, Velox rims with Falken 235/40/18z, Custom magnaflow exhaust, Custom motor mounts, Megan racing front strut bar, rear tint, airbox mod, custom camera mount, fully voided warranty
Quit bitching and race!
broken08 is offline
post #2 of 9 (permalink) Old 04-25-2006, 01:57 PM
dabears2k's Avatar
you might have bent a pin when reinstalling them...
-G.C. Lichtenberg
dabears2k is offline
post #3 of 9 (permalink) Old 04-25-2006, 04:10 PM
t_mo_t's Avatar
did u disconnect the negative terminal of the battery when u install ur speakers?
t_mo_t is offline
post #4 of 9 (permalink) Old 04-25-2006, 06:47 PM
Luke White's Avatar
Time to break out the owner's manual. There's a procedure to reset the auto-up/down if the battery is disconnected (for example). I can't remember exactly, but it's real simple - something like pull up on both front switches for X seconds with the ignition on or something like that.
Mine didn't work on delivery - a look through the manual cured my problem!
Later,
Luke
'06 Tungsten Gray 6s MTX
Luke White is offline
post #5 of 9 (permalink) Old 04-25-2006, 07:09 PM
Biohazardous's Avatar
Send a message via AIM to Biohazardous Send a message via Yahoo to Biohazardous
here u go
2006 Black 6i MTX. 35% tint all around debadged except front and rear mazda emblems. Removed door guards. Smoked side markers and rear reflector. CX-7 antenna. Kenwood headunit Two 10's 1000w amp and 600watt amp. Component Front Speakers and 6X8 rears. 18" Borbet XL Black and machined w/ toyo Proxy 4's 225/45/18. 2009 Black Cherry CX-7 GT Bose/Moonroof
Biohazardous is offline
post #6 of 9 (permalink) Old 04-25-2006, 07:58 PM Thread Starter
broken08's Avatar
thanks all!! the reprogramming thing worked perfect. What manual is that? i need one of those!!
-Sean
broken08 is offline
post #7 of 9 (permalink) Old 04-25-2006, 11:03 PM
t_mo_t's Avatar
that should be the user manual isn't??
t_mo_t is offline
post #8 of 9 (permalink) Old 04-26-2006, 08:48 AM
That is in my user manual. Glad we could help.
post #9 of 9 (permalink) Old 04-26-2006, 10:57 AM
mk706's Avatar
after disconnecting my battery this weekend i ran into the same problem- and i already knew about reprogramming the windows. anyways, as soon as i noticed the auto-windows didn't function i got a knot in my stomach until i was able to stop & reprogram; then i was able to breath a sigh of relief.
2006 MS6-GT Black Cherry Mica - Sold!
2007 Mazda CX-7 GT-AWD Crystal White Pearl
2005 M6s-5door Steel Gray - traded in
2004 M6s-4door Sepang Green - traded in
Semper Fidelis
mk706 is offline
