Apexcone HID Bulb Failure? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 9 (permalink) Old 04-15-2006, 07:58 AM Thread Starter
Last night while I was driving my passenger side HID bulb went out after only a few months My question is would it be the bulb or the ballast that died? Any suggestions on what to do or that could fix the problem would be great.
Russell_C is offline
post #2 of 9 (permalink) Old 04-15-2006, 08:45 AM
MZBuckeye's Avatar
Swap the bulb to the other side and see if it works over there. If so, ballast. If not, probably bulb, swap the other bulb and see if that works.
The amount of failures of bulbs and ballasts in the Xtec/Apexcone line is amazing to me.
MZBuckeye is offline
post #3 of 9 (permalink) Old 04-16-2006, 01:10 PM Thread Starter
I switched the ballasts from one side to the other and now none of the lights turn on .. What could be the problem now?
post #4 of 9 (permalink) Old 04-16-2006, 02:35 PM
dabears2k's Avatar
loose connection?
-G.C. Lichtenberg
dabears2k is offline
post #5 of 9 (permalink) Old 04-16-2006, 06:44 PM
t_mo_t's Avatar
oh, btw, have you tried taking out ur HID and test them using a constant 12V battery terminals (as what u would do once u get ur HID), see if they turn on... test each of the ballast with either bulbs..... see if ur HID fucked up or ur stock wiring.... (if not fuse-wise)
t_mo_t is offline
post #6 of 9 (permalink) Old 04-16-2006, 07:39 PM Thread Starter
No I have not done that. Do you mean place the negative cable for the HID lights on the negative car battery terminal?
post #7 of 9 (permalink) Old 04-16-2006, 10:11 PM
t_mo_t's Avatar
yes... putting +(ballat) to battery + and - (ballast) to ground (either battery or ground), that way u r bypassing the whole stock harness... if that works, then i guess it's about the stock wiring...
t_mo_t is offline
post #8 of 9 (permalink) Old 04-17-2006, 08:51 AM Thread Starter
Thanks for the help T Mo. I have figured out that I have a bad ballast and 2 fuses were blown.
post #9 of 9 (permalink) Old 04-17-2006, 09:36 AM
t_mo_t's Avatar
np...
2 fuses in the main fuse box for the lowbeam have blown??? ....holy.... did u wrap electrical tape for the negative connector inside the headlight? they might have touched positive connectors or something.... when i install hid kits, i always make sure i wrap electrical tape around the neg and pos connectors...
t_mo_t is offline
