Dash lights brightness - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 9 (permalink) Old 03-13-2006, 05:10 PM Thread Starter
I might be going crazy, but after my dealer replaced my PCM after frying it from an attempted flash, my instrument cluster dash lights now get very dim when I switch my parking or headlights on.
If I turn my headlights on in the daytime due to rain it seems much, much dimmer than it was previously.
I tried adjusting that little wheel next to the TCS toggle, and it's up all the way. If you hit the "Dimmer" button next to the radio/climate control display, that only affects the radio/climate control display.
The radio/climate control display at its lowest setting (using the Dimmer button in the center console) is about the same brightness as my instrument cluster when my parking lights are on.
Is this normal? Was my dash stuck in 'bright mode' before getting the new PCM? I don't like having such a dim dash during a rainstorm.
Arcanlaw
Arcanlaw is offline
post #2 of 9 (permalink) Old 03-13-2006, 05:14 PM
dabears2k's Avatar
Could be a bad connection. Take it back and have them check. It should be very vibrant
-G.C. Lichtenberg
dabears2k is offline
post #3 of 9 (permalink) Old 03-13-2006, 05:14 PM
There should be a button right on the odometer to change the brightness... at least there is on mine.. its weird having three brightness adjustment toggles/switches
Koopiskeva is offline
post #4 of 9 (permalink) Old 03-13-2006, 05:17 PM
dabears2k's Avatar
That is only if you have the sport guages that have EL. Not the regular guages
-G.C. Lichtenberg
post #5 of 9 (permalink) Old 03-13-2006, 05:19 PM
I see. /me goes to play with other toggles >_>
post #6 of 9 (permalink) Old 03-13-2006, 06:11 PM
does the dimmer button next to the LCD read-out affect the dash lights, or is it just for the LCD?
pololance6i is offline
post #7 of 9 (permalink) Old 03-14-2006, 12:52 PM
Mz6GreyGhost's Avatar
Quoted: 840 Post(s)
Groaned at 6 Times in 3 Posts
Just the LCD.
Mz6GreyGhost is online now
post #8 of 9 (permalink) Old 03-14-2006, 06:56 PM Thread Starter
That's exactly what it was, thanks. Never even noticed that button before... and yeah, it's very weird to have 3 different brightness controls.
Arcanlaw is offline
post #9 of 9 (permalink) Old 03-15-2006, 01:15 PM
itbeanew1's Avatar
Send a message via AIM to itbeanew1 Send a message via MSN to itbeanew1 Send a message via Yahoo to itbeanew1
which is i suppose why they took the dimmer buttons out on the 05 and newer models. they are now controlled with the dimmer wheel. I personally like all my lil buttons.
btw, with your lights off (gauges in daytime mode) you can set 1 of the i think 5 brightness levels for daytime intensity using this button.
Blazing Copper 04 6s MTX Sedan
Custom interior ambiant lighting, Airbox Mod (sometimes), Mazdaspeed6 tails, custom installed lower fogs (burnt out. need to get the kit)
RIP
itbeanew1 is offline
