LED Side Mirrors... Fitment PICS and wiring - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #11 of 30 (permalink) Old 02-15-2006, 02:32 AM
Mazda Gremlyn's Avatar
Exactly what I just told you about over IM. I'm not sure if the stalk controls the power for the lights or controls the power to a relay, so you'd want to check the voltage of the line.
2004 Mazda6s MTX: Gone...
Mazda Gremlyn is offline
post #12 of 30 (permalink) Old 02-15-2006, 07:00 AM
Hum
Hum's Avatar
I drilled a hole through the mirror back, went through the door and out to the side indicator, very easy. But I only had 2 wires so my LEDs are only indicator. With 3 wires, as said above 1 is a ground, you can just attach that to a bolt in your door, the other one will be your lights, and the other your indicator. Good luck.
[attachmentid=10489]
Hum is offline
post #13 of 30 (permalink) Old 02-15-2006, 11:33 AM Thread Starter
blackmagik_13's Avatar
I drilled the holes, no problem there, and I know which wires are what for the LED's.
I need to know what wires perform what function on the gauge cluster wiring harness'.
blackmagik_13 is offline
post #14 of 30 (permalink) Old 02-15-2006, 11:36 AM
dabears2k's Avatar
I would use the power off the side markers. If I remember from installing my remote starter, the blinker wires from the steering column are very low power and only trigger a relay.
-G.C. Lichtenberg
dabears2k is offline
post #15 of 30 (permalink) Old 02-15-2006, 01:38 PM
FICHSTIX's Avatar
That's why I hooked LED wire pos to head light and neg to the wire (that was disconnected to do the side
markers blink). I used a coat hanger to get the wires through the door. When I dont have the meter I use
my 12v Battery from my hand drill and touch the wire untill I get the right connection.
`.. , . .`.. ><((((>`..`..`...ZOOM-ZOOM!!><((MS6))>
FICHSTIX is offline
post #16 of 30 (permalink) Old 02-17-2006, 12:22 AM
HowyKaos's Avatar
hey heated mirrors wouldnt play any problems w/ the led covers right?
HowyKaos is offline
post #17 of 30 (permalink) Old 02-17-2006, 01:14 AM Thread Starter
I don&#39;t know. I don&#39;t have heated mirrors.
post #18 of 30 (permalink) Old 02-17-2006, 01:50 PM
FICHSTIX's Avatar
You only lose the heated mirrors if you replace the OE mirrors. They still function the same with just cover&#39;s.
FICHSTIX is offline
post #19 of 30 (permalink) Old 02-17-2006, 02:32 PM
austinhusker's Avatar
I drilled the holes, no problem there, and I know which wires are what for the LED&#39;s.
I need to know what wires perform what function on the gauge cluster wiring harness&#39;.
You get the wiring all figured out yet so I can just do what you did for mine!
"Chipotle sucks ginormous donkey balls" - Blue Solrac
austinhusker is offline
post #20 of 30 (permalink) Old 02-17-2006, 07:52 PM
HowyKaos's Avatar
cool cool, cuz i dont even know why i have heated mirrors, i live in so cal. i dont even know what snow or ice on the road is like!
HowyKaos is offline
