Hid Wiring - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 4 (permalink) Old 02-12-2006, 12:35 AM Thread Starter
6iGuy's Avatar
How would I go about wiring hid directly from the battery and then to a switch?
6iGuy is offline
post #2 of 4 (permalink) Old 02-12-2006, 10:26 AM
Cornholio's Avatar
Probably the best way is to use a relay (5-pin Bosch type). Use the factory low-beam headlight wire as a trigger to energize the relay. You can either buy a universal harness or you can make one. Just make sure you use a decent primary wire (14 AWG for each ballast and 12 AWG from the battery to the relay, if you are using 1 relay). If you use 2 relays (1 for each ballast), then you don't need to use 12 AWG between the battery and relay (14 AWG will suffice).
You don't want to run the HID (+) wire directly through the switch because it will draw alot of current at startup, which means all of that power will be running into the dash. Also, switches typically aren't designed to handle that much current (up to 30 amps) anyway.
Also, make sure you fuse the ballasts (15 amp fuse). You can also fuse the wire between the battery and the relay (30 amp fuse if you use 1 relay).
Setting it up this way, it will enable you to use the OEM headlight switch stalk to turn the HID's on.
Here is a wiring diagram from HIDPlanet.
Alan
Teamwork is essential. It gives the enemy someone else to shoot at.
Cornholio is offline
post #3 of 4 (permalink) Old 02-12-2006, 07:56 PM Thread Starter
6iGuy's Avatar
When you say factory low beam wire, do you mean the brown wire that connected to the factory bulb or the blue/green wire in the instrument cluster?
6iGuy is offline
post #4 of 4 (permalink) Old 02-12-2006, 08:16 PM
Cornholio's Avatar
The wire that connects to the H1 bulb (brown wire).
There is another place that you can get the signal from if you want. You can remove the same wire from the connector that plugs into the headlight. It's a matter of extracting the female terminal pin from the headlight connector.
Alan
