HID issue. - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #11 of 41 (permalink) Old 11-13-2005, 07:52 PM
MZBuckeye's Avatar
Betcha its a bad ballast. If a fuse blew, it'd stay off completely. Best contact your Xtec dealer.
MZBuckeye is offline
post #12 of 41 (permalink) Old 11-13-2005, 07:54 PM Thread Starter
zxc1104's Avatar
Send a message via AIM to zxc1104 Send a message via MSN to zxc1104 Send a message via Yahoo to zxc1104
Originally posted by MZBuckeye@Nov 13 2005, 08:52 PM
Betcha its a bad ballast.* If a fuse blew, it'd stay off completely.* Best contact your Xtec dealer.
[snapback]556611[/snapback]
that's what i was thinking... hmm. i emailed xenondepot. just need him to get back to me
i hate the gay cops here, now i gotta be careful
zxc1104 is offline
post #13 of 41 (permalink) Old 11-13-2005, 08:00 PM
MZBuckeye's Avatar
Swap the ballast over to the driver's side and see if it does it. Then you'll know for sure.
post #14 of 41 (permalink) Old 11-13-2005, 09:59 PM Thread Starter
zxc1104's Avatar
Originally posted by MZBuckeye@Nov 13 2005, 09:00 PM
Swap the ballast over to the driver's side and see if it does it.* Then you'll know for sure.
[snapback]556615[/snapback]
i'll have to try that... hmm... back to takin the shit apart
zxc1104 is offline
post #15 of 41 (permalink) Old 11-13-2005, 11:23 PM
falcontx's Avatar
Just thought I'd take a moment to address this on behalf of XtecUSA.
Sometime in the last couple months, the factory received a bad batch of voltage regulators. As a result, many of the ballasts that were created using these have had problems. The problems are always as described. Sometimes the lights will flicker and go off, but can be switched off and then back on and work fine, while other times, the bulb simply will not come on at all. This will not harm your car in any way, so you should not be concerned about continued use of your HIDs while they are doing this.
As soon as the problem became apparent, the factory began to investigate the cause of the problem, but it has taken them some time to figure out the exact cause, so some ballasts still managed to make their way into the hands of consumers. The problem has now been fixed, and should not rear it's ugly head in the future.
For now, if you are experiencing these problems, you should definitely contact your vendor, whether it be myself or someone else. They will be able to provide you with options for getting your ballast replaced. Although a deposit may be needed up front, there should be no additional cost to you once the exchange has been completed.
We do, and will continue to, stand behind the Xtec product and will do all that is necessary to ensure your satisfaction.
Are you one of our valued customers? Join The RPM Crew today and help spread the word! --
Come check out our website! --
-- We have a huge selection of parts for the Mazda 6 and Mazdaspeed 6!
Like us on Facebook for news and discounts! --
falcontx is offline
post #16 of 41 (permalink) Old 11-14-2005, 12:14 AM Thread Starter
zxc1104's Avatar
As soon as the problem became apparent, the factory began to investigate the cause of the problem, but it has taken them some time to figure out the exact cause, so some ballasts still managed to make their way into the hands of consumers.* The problem has now been fixed, and should not rear it's ugly head in the future.
[snapback]556747[/snapback]
that's awesome. mine flicker, then shut off, and when i turn it back on... it does the same thing.
i emailed xenondepot. i guess i shall wait and see what he has to say.
zxc1104 is offline
post #17 of 41 (permalink) Old 11-14-2005, 07:53 AM
Wiggum's Avatar
Quick question as I didn't see it in your post.... was the problem addressed and corrected??? Meaning all new kits ordered will be problem free??
2006 Mazdaspeed6 - Grand Touring w/ Moonroof - Black/Black-
2005 Mazda6s - Fully loaded w/ every option but ATX - Steel Gray/Black (SOLD) -
2006 Mazda6i - Sport package w/ Bose/Moonroof ATX - Dark Cherry/Black -
Wiggum is offline
post #18 of 41 (permalink) Old 11-14-2005, 08:24 AM Thread Starter
zxc1104's Avatar
[snapback]556837[/snapback]
i still am waiting for a response from XenonDepot.
zxc1104 is offline
post #19 of 41 (permalink) Old 11-14-2005, 10:39 AM Thread Starter
zxc1104's Avatar
is this something that's fixable?
zxc1104 is offline
post #20 of 41 (permalink) Old 11-14-2005, 01:53 PM
sry110's Avatar
Send a message via AIM to sry110
[snapback]556923[/snapback]
As I mentioned earlier, I have this same problem and after I contacted FalconTX he had a new ballast shipped to me. I also purchased XTec's wiring harness, which bypasses the stock wiring with regards to power supply (i.e. hooks up directly to the battery, instead of drawing power through the stock headlight wiring). The new ballast should take care of the problem, but in case it doesn't and I keep having to turn the headlights on/off/on again to get them both to stay on, I don't want to be cycling the power as such through the stock wiring. I say this because the headlights draw a lot of power when they first turn on, then they run cooler than stock on a continuous basis. The Xtec harness is beefy to say the least, because it is sized for the peak load during bulb ignition.
Anyway that's a little off the topic, and I haven't even done my re-install yet to replace the ballast and install the wiring harness, but I like the peace of mind that the directly-connected wiring harness will give me.
Old Car --> 2003 Mazda 6s 5MT, Sport Package, some goodies
Current Car --> 2006 Nissan 350z 6MT, some goodies : )
sry110 is offline
