HID Fuse rate? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 4 (permalink) Old 11-09-2005, 06:09 PM Thread Starter
Hi guys,
I test fitted my Hella HID kit yesterday. When I turn on for the first time I burn the 10amp fuse. I then changed the fuse to 15amp so the problem stops. I wonder if the problem will occur again. Right now I am using the factory headlight harness plus the wires that came with the kit to light the HID. Do I need relay harness that draws power directly from battery to Hella ballasts? If I don't do that will my HID have a problem in the future? Any help is greatly appreciated
blackhatch6 is offline
post #2 of 4 (permalink) Old 11-10-2005, 03:34 AM
Originally posted by blackhatch6@Nov 9 2005, 04:09 PM
Hi guys,
I test fitted my Hella HID kit yesterday.* When I turn on for the first time I burn the 10amp fuse.* I then changed the fuse to 15amp so the problem stops.* I wonder if the problem will occur again.* Right now I am using the factory headlight harness plus the wires that came with the kit to light the HID.* Do I need relay harness that draws power directly from battery to Hella ballasts?* If I don't do that will my HID have a problem in the future?* Any help is greatly appreciated
[snapback]554065[/snapback]
Hhhahahaha I burned like 5 10amp fuses. I changed to 15 amp fuses and I had no more problems with my HIDs.
cachorropedorro is offline
post #3 of 4 (permalink) Old 11-10-2005, 04:45 PM Thread Starter
Originally posted by cachorropedorro@Nov 10 2005, 03:34 AM
Hhhahahaha I burned like 5 10amp fuses.* I changed to 15 amp fuses and I had no more problems with my HIDs.
[snapback]554426[/snapback]
I think I'll do the same. If it happens again I guess I'll buy one of those relay harness.
post #4 of 4 (permalink) Old 11-15-2005, 03:56 AM
hahaha i have a relay harness...
