Cigarette lighter capacities - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 8 (permalink) Old 10-23-2005, 04:52 PM Thread Starter
Im about to hard wire an inverter into my 6 and plan on using the leads for the cigarette lighter. The inverter is 400 watt continuous and 800 watt max which will draw 33 and 66 amps. I know the wiring isnt rated for this. I want to upgrade the 15 amp fuse that the lighter uses now but i dont want to fry the wiring. how big can i go? also, is the cigarette lighter in the arm rest always on? or is it switched with the ignition?
VTblack6 is offline
post #2 of 8 (permalink) Old 10-23-2005, 05:49 PM
austinhusker's Avatar
I don't know about most of your questions but I do know the lighter is switched with the ignition.
"Chipotle sucks ginormous donkey balls" - Blue Solrac
austinhusker is offline
post #3 of 8 (permalink) Old 10-23-2005, 07:57 PM
Mazda6sMtx's Avatar
Check the fuse in the fusebox and you will find your answer. I've never looked or I'd just tell you.
Mazda6sMtx is offline
post #4 of 8 (permalink) Old 10-23-2005, 10:14 PM Thread Starter
the fuses are 15 amps for each of the lighters. but i know the wiring can handle more.....but how much more?
VTblack6 is offline
post #5 of 8 (permalink) Old 10-23-2005, 10:20 PM
Send a message via AIM to chambers7867 Send a message via Yahoo to chambers7867
maybe this could help you. i dont want to shit on your grass but it's not as easy to say "how many amps in a volt" read this and this will tell you everything you will ever need to know about everything!
What are amps, watts, volts and ohms?
MAZDA 6i 2.3l: Magnaflow exhaust, InJen intake, Cpe battery tray, Oddssey lightweight battery, Nitrous Express efi wet kit, Nos bottle warmer, Nos bottle Blanket, MR. Racing nitrous plate, Zex purge kit, AutoMeter Nitrous, Tranny, Air/fuel, Volt gauge (sportscomp) Lotek 3 gauge pod, MoMo Duke shiftknob, MoMo endurance shiftboot, Powdercoated valve cover, Powdercoated wheels, Rotra rotors, BenDix brake pads, Stainless steel brake lines, stainless steel fuel lines, MR. Racing fuel rail, Autometer fuel pressure gauge, custom strut bar, 10% tint all around, tinted taillights and sidelights, Planet audio 5x7 speakers all around, Jvc Exad dvd player headunit. carbon fiber hood.
chambers7867 is offline
post #6 of 8 (permalink) Old 10-23-2005, 10:53 PM Thread Starter
im an engineer, i understand electricity. my inverter is 400 watt continuous and 800 watt max. on a 12 volt circuit (i know its actually closer to 14.4v) that will draw approximately 33 and 66 amps. P=VI. I guess i could look up the gauge wire and see what that is rated but there really is no way i can trace all of the wires to find their gauges as well as all of the connectors. maybe i will just run wires directly from the battery so it will be always on and i know i wont light my car on fire.
VTblack6 is offline
post #7 of 8 (permalink) Old 10-23-2005, 10:58 PM
Mazda6sMtx's Avatar
I would just run new wires to the battery and your own fuse. That way you are safe and you still use both lighters. Just add a switch in the line to disable the inverter, if it doesn't have a switch already. 10awg should be more than enough.
post #8 of 8 (permalink) Old 10-24-2005, 03:37 AM
nigelpinder's Avatar
I have a 350W inverter, then it was fully loaded on holiday this year (it beeps when its overloaded and it was occasionally beeping), after 5 hours it blew the cigarette lighter fuse !
So I am running a dedicated supply to a secondary cigarette lighter for my invertor from now on.
Nige.
nigelpinder is offline
