LED Equalizer Installation??? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 16 (permalink) Old 10-02-2005, 06:42 PM Thread Starter
nyyanks2always4's Avatar
I bought the equalizers to use with the LEDs. I tried to follow the instructions from ...
http://forum.mazda6club.com/index.ph...T&f=25&t=35380
...Do i need to splice the wires in the car or play with the adapter????
nyyanks2always4 is offline
post #2 of 16 (permalink) Old 10-03-2005, 05:51 PM
leftyrev's Avatar
Originally posted by nyyanks2always4@Oct 2 2005, 06:42 PM
I bought the equalizers to use with the LEDs.* I tried to follow the instructions from ...
[snapback]523421[/snapback]
huh?? they tap into the stock wiring , the diagram is in that post . what exactly is the problem your having ?
leftyrev is offline
post #3 of 16 (permalink) Old 10-04-2005, 09:05 AM Thread Starter
Yea i wish i knew. I've had other people even look at the disgram and nothing. Has anyone installed these already that can provide a picture of what they look like already done?
post #4 of 16 (permalink) Old 10-04-2005, 09:27 AM
Jax6S's Avatar
Did you see this?
You don't have to cut anything. Just put your turn signal wire to the splicing connector and press down hard. The connector will connect your turn signal wire with the load resistor wire as indicated in the installation diagram.
Do this on the other side (you have to do one for the + wire and the other for the - wire) and you're done.
2006 Black Mazdaspeed6
Jax6S is offline
post #5 of 16 (permalink) Old 10-04-2005, 11:22 AM Thread Starter
Its starting to make sense. I'll have to go home and see if i'm right!
post #6 of 16 (permalink) Old 10-04-2005, 12:22 PM
leftyrev's Avatar
Originally posted by nyyanks2always4@Oct 4 2005, 11:22 AM
Its starting to make sense.* I'll have to go home and see if i'm right!
[snapback]524755[/snapback]
dude this is so basic to install , i dont understand what problem your having . is it locating the wires on your car ? or not knowing how to use the connectors ?
leftyrev is offline
post #7 of 16 (permalink) Old 10-04-2005, 01:52 PM Thread Starter
not knowing how to use the connectors i think. Do i have to cut the wires in the car to connect them to the connector??
post #8 of 16 (permalink) Old 10-04-2005, 03:17 PM
Jax6S's Avatar
Read my post! I said on my previous post "you don't need to cut anything".
The load resistor will piggy back the current wires. That's why it's called splicing and not cutting. Look at the diagram below, do you see any cut?
You're making this harder than it's supposed to be.
Jax6S is offline
post #9 of 16 (permalink) Old 10-04-2005, 03:44 PM Thread Starter
Tell me about it, I know i am. I'll install them when i get home. Thanks for the help brotha!
post #10 of 16 (permalink) Old 10-07-2005, 02:23 PM Thread Starter
Everything worked perfect. I definatly made things harder than they realy are. Is there a way to protect the car and its components for the equalizer heating up. It got pretty damm hot and made me afraid that it will burn through the carpet or expose the wires.
