Brake Light Mod - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 7 (permalink) Old 08-13-2005, 10:07 PM Thread Starter
Send a message via Yahoo to phantom6
I did the brake light mod a while ago and it seems like the bulbs that are on the trunk are a bit dimmer then the ones on the fenders. Is this an optical allusion or did i do something wrong?
phantom6 is offline
post #2 of 7 (permalink) Old 08-14-2005, 03:54 PM
CvilleSix's Avatar
They should be about the same brightness. Do they look the same with the lights on? I.e., going from tail-light on to tail- and brake-lights on?
2003 Performance White 6i Sedan, MTX Used to have a turbo, now pursuing the DD dream
CvilleSix is offline
post #3 of 7 (permalink) Old 08-15-2005, 07:55 AM
Mz6GreyGhost's Avatar
Quoted: 840 Post(s)
Groaned at 6 Times in 3 Posts
You did nothing wrong, the inner tails on my car are SLIGHTLY dimmer as well, but I'm the only one that notices it, and I'd rather have them all working, instead of disconnecting them because they don't match perfectly!
Mz6GreyGhost is offline
post #4 of 7 (permalink) Old 08-16-2005, 08:21 AM
biofreak's Avatar
Send a message via AIM to biofreak Send a message via MSN to biofreak
mine all seem to match? i probably just can't tell
Tony
04 Onyx Black 6s
biofreak is offline
post #5 of 7 (permalink) Old 08-16-2005, 09:28 AM
Mazda6sMtx's Avatar
I agree with Mz6GreyGhost, the lights on the trunk are dimmer. I think this is do to the reflectors being different. The bulbs are the same so I see no reason why the outer two would be brighter.
Mazda6sMtx is offline
post #6 of 7 (permalink) Old 08-16-2005, 01:58 PM
Bulybuoy's Avatar
I dunno know if this would apply , but i changed the bulbs to leds recentlyy , and noticed that on the trunk , one was dimmer and one was brighter. they are all double contact/ double filament bulbs . changed the bulbs position , and the same position was still having the problem , so , swapped the wires , and that fixed the probelm . i just inverted the wires connecting to the side that was dimmer and it's now brighter = the bulb lights up as if breaking!
[COLOR=blue][SIZE=1][FONT=Optima][B]
JDM Mazda 6i Black Mica 2005
Santo Domingo , Dominican Republic
Bulybuoy is offline
post #7 of 7 (permalink) Old 08-21-2005, 03:05 PM
The red lenses are a different pattern and diffuse the light differently because they are actually designed as rear fogs for the Euro market.
Theres a big difference between real drivers and those who just hold a licence.
aaman is offline
