Xtec HIDs - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #11 of 15 (permalink) Old 08-12-2005, 04:52 PM Thread Starter
zxc1104's Avatar
Send a message via AIM to zxc1104 Send a message via MSN to zxc1104 Send a message via Yahoo to zxc1104
*bump*
zxc1104 is offline
post #12 of 15 (permalink) Old 08-12-2005, 09:08 PM
Bigbaddad's Avatar
Talking
When I took apart my headlight housing to install my DDE's, I cleaned off the double sided tape that came with the HID kit, and re-installed the ballast with 3M automotive double sided tape to the underside of the headlight housing (where the factory one goes). Make sure you clean the surfaces well to isnure a strong bond. I usually use denatured alcohol.
Aloha
大きく悪いお父さんのガレージ
*Spare parts available*
Bigbaddad is offline
post #13 of 15 (permalink) Old 08-15-2005, 03:48 PM Thread Starter
zxc1104's Avatar
i got it... i did the double sided tape... and then used zip ties to secure it into place
hope that holds it!
zxc1104 is offline
post #14 of 15 (permalink) Old 08-20-2005, 12:54 AM
Blue Solrac's Avatar
Send a message via AIM to Blue Solrac Send a message via MSN to Blue Solrac
I figure I better post so that no one follows the mistake I made:
Well uh...it seems I unintentionally mounted my drivers-side ballast a bit too close to the transmission... and so one night, after some hard driving, the wires started smoking. Turns out the ballast over-heated and totally fried (transmission gets very hot!) So make sure not to mount your ballast too close to any heat sources! I also contacted Jim from Xtec and he suggested I try "aluminum flashing" (which is available at any local hardware store.) Just make a 90 degree bend and use it as a heat shield.
Anyway, thats all from me. Hope you're enjoying your HIDs!
"I must admit, Chipotle is the best out there."
- austinhusker
Blue Solrac is offline
post #15 of 15 (permalink) Old 08-20-2005, 01:25 AM Thread Starter
zxc1104's Avatar
i got it below my headlights... one near my wheel well, and the other on the other wheel well... around/on the metal bar.
zxc1104 is offline
