retrofit? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 10 (permalink) Old 07-30-2005, 08:08 PM Thread Starter
can someone please explain to me the point of retrofitting our headlights are? i dont know much about wiring and shit like that, im mostly an engine man. and please dont flame me for this, i honestly dont understand it
imanaggie is offline
post #2 of 10 (permalink) Old 07-30-2005, 08:25 PM
zoomzoomfan's Avatar
*cracks knuckles*
Retrofitting is the process of installing FACTORY HIDs (i.e. entire projectors, ballasts and D2S bulbs) that were taken from another car (that comes with HIDs as standard equipment like BMW or Audi) into your Mazda6's headlights. To do so, you need to open up your headlights completely (by baking them open) and remove the existing projectors. You'll then replace them lock-stock-and-barrell with the new BMW/Audi projectors. This is, according to some, the ONLY acceptable way of putting HIDs into a 6.
Here's an EXCELLENT write-up on how to do this: LINKIE
A second method of installing HIDs into the 6 also exists. This method involves using a conversion kit (like Xtec, HIDS4U, etc), where you're simply swapping out the H1 halogen bulbs in your existing Mazda6 projectors with HID bulbs and adding the additional necessary ballasts and wiring (all included in the kit). Since the existing Mazda6 projectors are used, the headlight does not need to be baked open. Instead a hole is cut into the dustcap at the back of the projector housing to make space for the new bulb and to allow the new wiring to exit the headlight.
2004 Mazda6 GT Hatch I4 MTX
zoomzoomfan is offline
post #3 of 10 (permalink) Old 07-30-2005, 08:31 PM Thread Starter
thanks, i get it now
post #4 of 10 (permalink) Old 07-30-2005, 09:37 PM
t_mo_t's Avatar
very well-said !!!
t_mo_t is offline
post #5 of 10 (permalink) Old 07-30-2005, 10:08 PM
Hey, I learned from the best
post #6 of 10 (permalink) Old 07-31-2005, 12:45 AM
t_mo_t's Avatar
haha..... i c....
t_mo_t is offline
post #7 of 10 (permalink) Old 07-31-2005, 09:02 AM
travis0385's Avatar
Send a message via AIM to travis0385 Send a message via Yahoo to travis0385
which is usually more expensive?
i kno retrofitting is more work........ does one look better and perform better than the other?
2003 Mazda6i Speed Yellow
Appearance Package, ATX, Fogs, Injen CAI, 25% Tint, Sport Grille, Red Painted Calipers, Mazda Mp3 Player, Audiobahn 8000T amp powering two Alpine SWR-1222ds fiberglassed, Inverted Blacklight Parking Lights, Detailed Engine Cover, 18" Graphite Konig Troubles
travis0385 is offline
post #8 of 10 (permalink) Old 07-31-2005, 04:24 PM
[snapback]472584[/snapback]
Well... retrofitting can easily become more expensive than getting a conversion kit. But, it doesn't have to. I've been looking on eBay over the past month, and I've come across individual pieces for sale here and there that together make up all the necessary items in a retrofit. You'll end up spending $50 here, $200 there. In the end, you might actually be able to walk away will everything you need for about $500.
With a conversion kit, its all there in one box ready to go.
As far as quality goes, I'm afraid my answer is going to be subjective (biased). Since I myself plan to do a retrofit to my 6 and am pretty much ignoring the conversion kit method alltogether, I'd have to say that the retrofit method produces the best quality light possible.
With retrofitting, keep in mind that, more often than not you're getting high quality parts. You're getting a projector that's "tuned" to produce the proper sort of light at the right intensity, with a proper cutoff line and hotspots right were they're supposed to be.
With a conversion kit, you may very well end up with cheap components... and the light, although its strong and sharp, might not be directed properly.
post #9 of 10 (permalink) Old 07-31-2005, 06:18 PM
t_mo_t's Avatar
True that... there was once, a member of hidplanet was selling his retrofit for like 250USD shipped !!!! and it is for our car.... but a mazda6 owner got them, and still dont know who he is.... but that was the cheapest though....
i got mine 415USD shipped... and note in mind, if you wanna retrofit, always check whether the projectors are for both left and right !! not both left/right !!
t_mo_t is offline
post #10 of 10 (permalink) Old 08-01-2005, 07:53 AM
robinlb's Avatar
t_mo_t is a good guy
Ur cutoff beam pic on signature looks beautiful. I think u have successfully finished the work of bending shield.
robinlb is offline
