Maf Customizer - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 17 (permalink) Old 07-17-2005, 08:25 PM Thread Starter
My Maf Customizer was working perfectly fine, and now it doesn't. So I went back and rewired everything, I even took off the scotchlocks and spliced all the wires. And it's still not working. BTW, there is no CEL.
Could it be the Maf Customizer itself?
Please someone help.
100% stock, I don't like mods.
Ryobob is offline
post #2 of 17 (permalink) Old 07-17-2005, 08:56 PM
Send a message via Yahoo to monkeyboydrew
Believe there was another guy here that thought his MAF box went tits up also, I would give the guy over at CPE a call and see what can be done about it. Hope this helps a little...if not then.................... BUMP
monkeyboydrew is offline
post #3 of 17 (permalink) Old 07-17-2005, 09:34 PM
CLTatenza's Avatar
How do you know exactly that its your MAF?
A suggest that I think would be nice on the MAF is a LED showing that it is powered and working correctly, I dont know if cp-e could some how work that out.
CLTatenza is offline
post #4 of 17 (permalink) Old 07-17-2005, 10:09 PM
Hoosteen's Avatar
well, if your MAF isn't working, i don't believe your car would start.
You need to explain a little more.
Is you car still running but you don't feel the gains?
or does your car not start?
Or is your car bucking uncontrollably?
I've done a little (lot) of trouble shooting with my CPE... you need to explain more.
Hoosteen is offline
post #5 of 17 (permalink) Old 07-17-2005, 10:25 PM Thread Starter
Well, here's the thing. When I first got the kit, it wasn't working. I knew this because I wasn't fealing any gains. I left it as is, and for some odd reason it started to work. I was definitely feeling the gains. Then I started to get a CEL flicker. Finally the CEL stayed on, but I was still feeling the power gains. Just recently, the CEL went out, but I'm not feeling the power any longer. So I figured it was a bad connection, rewired everything and it feels like it's back to stock. So I'm very confused.
Ryobob is offline
post #6 of 17 (permalink) Old 07-17-2005, 11:49 PM
Hoosteen's Avatar
Oh yeah.... i actually read your entire thread about your situation.
I know its going to be a pain in the ass and you're going to feel like a punk, but you gotta take it back to CPE.
It shouldn't be throwing a CEL in the first place.... just be reasonable and let them know that you would like a replacement as it has always been faulty... they know your situation and i'm sure they'll take your old one and refurbish it and give you a new one. They can't afford to lose face with the M6 community as that is their biggest selling point.
Its not a faulty connection- if it were a faulty connection most likely your car will not start... die.... or buck erratically.
Give em a call.
Hoosteen is offline
post #7 of 17 (permalink) Old 07-18-2005, 07:17 AM
crossbow's Avatar
If your maf fails, but is still connected, the car will start, and the car will run. It'll just run in safe mode, won't rev, won't go past a certain rpm, and will feel like its going to explode.
The car has redundant intake sensors. MAF, IAT, and MAP. If one has an issue, the other two take over but throw the car in safe mode.
99.999999999% of CP-E problems are loose connectors. I think there was only ever a SINGLE case of a bad mafci system, and that was with one of the very early batches...since then every single person who sent cp-e a mafci back to test, has been fine. Its just the connectors (scotchblocks) going loose.
crossbow is offline
post #8 of 17 (permalink) Old 07-18-2005, 07:50 AM
I was the other one with the recent MAFci problem. I'm certain its not my connectors though, I went back and soldered everything. I drove it all weekend with the soldered connections just to make sure the light wouldn't go out, I'm sending in my box today, I'll post the results. The only thing left is either my MAF sensor failed or its the box.
That indicator light on the box would be great. My CEL does stay lit though.
diesel5599 is offline
post #9 of 17 (permalink) Old 07-18-2005, 10:46 AM
crossbow's Avatar
A scanner would help diagnosis greatly...
crossbow is offline
post #10 of 17 (permalink) Old 07-18-2005, 10:50 AM Thread Starter
alright, i opened it up and took a look at it.
the top light is on, the bottom light is blinking.
does this mean anything?
Ryobob is offline
