need some help!! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 10 (permalink) Old 06-24-2005, 08:24 PM Thread Starter
Bulybuoy's Avatar
well guys i just installed my hid last week and in these two days it has been raining alot and when i trun mi lights on there is getting like vapor or steam inside the headlamps of my car and i sealed everything good and don't know whyy ?? so why that some help pliiis i'sm so mad of that!!!
[COLOR=blue][SIZE=1][FONT=Optima][B]
JDM Mazda 6i Black Mica 2005
Santo Domingo , Dominican Republic
Bulybuoy is offline
post #2 of 10 (permalink) Old 06-24-2005, 11:05 PM
ksource's Avatar
You did use silicone to seal it right?
I have the problem with one of my lights and not the other, however when I opened it I didn't seal either one because I need to get in it again soon, plus it's summer and it rarely rains.
The only thing is probably the seal around the housing, probably?
2006 ms6 v.red -
P : [AEM SRI, ATP DP, Cobb AP, Denso ITV22, Corksport Catback, CP-e FMIC, CP-e Nviscid TIP, PG CDFP Upgrade, Saikou Michi OCC, SU Motor Mount, Synapse Synchronic BOV, TWM Stage 1]
V : [AE Replica Grille, Car_LED Tail Lights, Halos, JDM Visors, Megan Springs, Smoked Rear Reflectors, 8000k HID Fog.]
* BSD
2005 6i blk (Sold) - Eibach Springs, DDE Halos
1993 240sx red (Sold) - Front and Rear Strut Bars
ksource is offline
post #3 of 10 (permalink) Old 06-25-2005, 05:07 AM
CvilleSix's Avatar
Hopefully the housing wasn't taken apart to just install HID's. The only necessary modification is drilling a ~1" diameter hole in the dust caps to allow for the longer bulb and wiring (which should come through a grommet). Did you install the grommet correctly? (dumb question, but...)
2003 Performance White 6i Sedan, MTX Used to have a turbo, now pursuing the DD dream
CvilleSix is offline
post #4 of 10 (permalink) Old 06-25-2005, 01:55 PM Thread Starter
Bulybuoy's Avatar
Ok , i didn;t take apart the headlight for installing the hids. i took the headlamp off , took off the dust cap , drilled the hole in it! put in the grommet! very carefully! sealed the part where the wires come through the grommet! and the new hole where the +\- wires pass too! and that;s it!!!
i mean , i put silicone on the grommet and cables going out of it , since it ripped off a bit when passing the +\- cables!
but do i have to put silicone alsoo on the grommet and to where it contacts the dust cap?!?!? i dont think so ,cuz if so , what;s the grommmets function then ?!?!! right?!?!?!?!?!
thnx!!!!
Bulybuoy is offline
post #5 of 10 (permalink) Old 06-27-2005, 06:23 AM
If you sealed everything up properly then it just sounds like a matter of your grommets not being seated all the way...double check! I know its annoying as hell to see the fog in your lenses..thats my word
wpip is offline
post #6 of 10 (permalink) Old 06-28-2005, 12:12 AM Thread Starter
Bulybuoy's Avatar
Yeahh ,i checked everything like 1000 times man! i am too carefull when working on my car , and very very ifffy about everything! the only thing i can think of , is the grommet irself not sealing quite good , but what i dont wanna doo is putting some silicone all over the grommet and the dust cap , to make a tight seal there , cuz if i wanna take off something, or open there , it's gonna be a pain!!!
dunno what to do!
Bulybuoy is offline
post #7 of 10 (permalink) Old 06-28-2005, 12:16 AM
Axion's Avatar
Quoted: 4 Post(s)
Man i put a BUNCH of silicone all over the back of my dust caps, it peels off if you ever need to re-do anything. Just load it up, spread it all around the edge and the inside part of the grommet.
Axion is offline
post #8 of 10 (permalink) Old 06-28-2005, 12:33 AM
blackmagik_13's Avatar
Originally posted by Axion@Jun 27 2005, 11:16 PM
Man i put a BUNCH of silicone all over the back of my dust caps, it peels off if you ever need to re-do anything. Just load it up, spread it all around the edge, throw some jelly on there and some doritos, and there ya have it.* A Silicone, grommet, jelly and dorito sandwich, Mmmm Mmmmm goodness
[snapback]441656[/snapback]
blackmagik_13 is offline
post #9 of 10 (permalink) Old 06-28-2005, 12:39 AM
Axion's Avatar
Quoted: 4 Post(s)
Originally posted by blackmagik_13@Jun 27 2005, 11:33 PM
[snapback]441663[/snapback]
Har Har...
Axion is offline
post #10 of 10 (permalink) Old 06-29-2005, 11:59 PM Thread Starter
Bulybuoy's Avatar
jajajjaa , yeah , i think i am gonna do that! just when i get back! i out of the countryy right now! ( don;t wanna get back by the way , this is heaven )
but will seal that thing alll over as soon as i can|!!!!
thnx guys!
Bulybuoy is offline
