Integrated fog light keeps burning out - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 6 (permalink) Old 06-06-2005, 08:23 AM Thread Starter
nilsenm's Avatar
Has anyone had any problems with their integrated fog lights burning out. I'm on my second set of bulbs and they look like they are dimming all ready. I had this problem a couple of months ago also. i want to bring it to the dealership but i just installed fog lights and they will probably blame it on that. any one have any ideas how I can check this? i was going to buy xtreme white h3 bulbs but i dont want to waste the money if they are just going to burn out again.
nilsenm is offline
post #2 of 6 (permalink) Old 06-06-2005, 09:47 AM
did you replace the bulbs with regular bulbs the first time? If not you sure you running the same watts? Did this problem start after the fogs or before? The delear can try to blame your fogs but they need to prove it to you. I know dealers are dicks trust me i know this all to well.
Fully working LCD Display
r1labs is offline
post #3 of 6 (permalink) Old 06-06-2005, 10:49 AM Thread Starter
nilsenm's Avatar
Originally posted by r1labs@Jun 6 2005, 09:47 AM
did you replace the bulbs with regular bulbs the first time?* If not you sure you running the same watts?* Did this problem start after the fogs or before?* The delear can try to blame your fogs but they need to prove it to you. I know dealers are dicks trust me i know this all to well.
[snapback]425334[/snapback]
i was thinking that too, but i used 55 watts. is that the same? this problem started before the fogs were installed but came again after. i wired the fogs into the drivers side head lights and that is the side with the fog problem. Could i have done somethign to cause it to burn out.
nilsenm is offline
post #4 of 6 (permalink) Old 06-06-2005, 06:16 PM Thread Starter
nilsenm's Avatar
Originally posted by nilsenm@Jun 6 2005, 10:49 AM
i was thinking that too, but i used 55 watts.* is that the same?* this problem started before the fogs were installed but came again after.* i wired the fogs into the drivers side head lights and that is the side with the fog problem.* Could i have done somethign to cause it to burn out.
[snapback]425388[/snapback]
nilsenm is offline
post #5 of 6 (permalink) Old 06-06-2005, 08:24 PM
Hoosteen's Avatar
make sure you're not touching the bulb with your fingers when installing it.... the oils will heat up the bulb and burst it.
Hoosteen is offline
post #6 of 6 (permalink) Old 06-07-2005, 10:45 AM
I am on my way to the dealership as we speak. I was going to make a new post and then saw this one about my very issue! I am on my 3rd set of bulbs in 4 months. They have run every test and checked all the wiring and they can not find anything. They keep chalking it up as bad bulbs, etc but something else has to be wrong.... I am sick of taking time off of work and shit to get these bulbs replaced.
Anyone know of anything that is going on? Ugh, this is so annoying.
Mike
crazyflash4 is offline
