RPM Gauge - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #21 of 28 (permalink) Old 06-01-2005, 09:36 PM
leftyrev's Avatar
pic
leftyrev is offline
post #22 of 28 (permalink) Old 06-01-2005, 10:04 PM
leftyrev's Avatar
ignition coil on a 4 cyl pic and manual . only thing is that has 2 signal wires and not sure if that could be used . i know some tachs you could change the setting to what cylider car you have to correct the double signal the 4 cyl. ignition gets
no idea if the 6 cyl. has the same type of ignition as the 4 cyl .
also just remembered the wires form the directed electronics that i gave before were for a 2004 mazda 6 6 cyl. it might be different colors on other years .
leftyrev is offline
post #23 of 28 (permalink) Old 06-01-2005, 10:08 PM
84FordMan's Avatar
V6 uses coil-on-plug and from my wiring diagrams, one wire is only a ignition run reference, and the second is a constant 12V source.
1994 Mazda B3000 SE
Daily driver
84FordMan is offline
post #24 of 28 (permalink) Old 06-01-2005, 10:20 PM Thread Starter
Send a message via AIM to YanMan08
I've try to connect the tach to one of the neg on the coil and the tach works. the only thing is the stock one would be at 3 rpm and the other tach only reads 1. Its freakin wierd.
YanMan08 is offline
post #25 of 28 (permalink) Old 06-01-2005, 11:19 PM
leftyrev's Avatar
Originally posted by YanMan08@Jun 1 2005, 10:20 PM
I've try to connect the tach to one of the neg on the coil and the tach works.* the only thing is the stock one would be at 3 rpm and the other tach only reads 1. Its freakin wierd.*
[snapback]422587[/snapback]
do you have a manual for the tach ?what brand is it ?
i think on tachs there is a setting to adjust the pulses per revolution (PPR), you can adjust that
i know the stewart Warner tachs have them . check out the PDf file and see waht im talkingbaout . different brands might be different way of adjusting i guess
here is a link on one of their tachs PDF file
http://www.sw-performance.com/downloadfiles/15.PDF
leftyrev is offline
post #26 of 28 (permalink) Old 06-02-2005, 01:20 PM Thread Starter
i think on tachs there is a setting to adjust the pulses per revolution (PPR),* you can adjust that
i know the stewart Warner tachs have them . check out the PDf file and see waht im talkingbaout . different* brands might be different way of adjusting i guess
[snapback]422638[/snapback]
theres a setting on the back that says 4 6 or 8. i put it on everyone and nothing. same shit. the gauge is CP. i got it off ebay.
YanMan08 is offline
post #27 of 28 (permalink) Old 06-02-2005, 02:31 PM
leftyrev's Avatar
Originally posted by YanMan08@Jun 2 2005, 01:20 PM
theres a setting on the back that says 4 6 or 8.* i put it on everyone and nothing. same shit.* the gauge is CP.* i got it off ebay.
[snapback]422953[/snapback]
CP? never heard of it . do you have the 4 cyl. or the 6 cyl. ?
leftyrev is offline
post #28 of 28 (permalink) Old 06-02-2005, 05:45 PM Thread Starter
[snapback]422989[/snapback]
v6
here is the link of the rpm gauge.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33679
i think im just gonna get a different gauge. i just hope i can get my money back.
YanMan08 is offline
