left/right adjustment for low beams - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 11 (permalink) Old 04-25-2005, 10:47 AM Thread Starter
OK, so I pretty much got down pat on making the adjustments to
- left/right up/down for the high beams
- up/down for the fogs
- up/down for the lows
I spent a good hour or so last night making the above adjustments. But how the hell are you suppose to reach the right/left adjustment for the lows?!!!
And can I buy the proprietary Mazda tool for adjusting the headlights?
'05 6s hatch 6-speed auto: optimized AEM CAI, Racing Beat exhaust, VVME 4300k 55watt HID, Kosei K1-TS, 215-50-17 Continental DWS, Progress rear sway bar, RB front sway bar, GTSpec ladder brace, Mazdaspeed springs with 3/4" rear lift spring spacer, Bilstein HD shocks
Have "saggy butt" syndrome? Want to even out your drop?
flarearrow is offline
post #2 of 11 (permalink) Old 04-25-2005, 12:35 PM
Axion's Avatar
Quoted: 4 Post(s)
Umm its not hard at all... I got in there with a phillips screwdriver, and then the right sized allen wrench and did it in a minute or so..
Axion is offline
post #3 of 11 (permalink) Old 04-25-2005, 12:45 PM
phishstics's Avatar
Send a message via AIM to phishstics
out of curiosity, what was the phillips for?
btw, the right sized allen wrench is 6.
phishstics is offline
post #4 of 11 (permalink) Old 04-25-2005, 02:17 PM Thread Starter
[snapback]398666[/snapback]
Maybe that's because you have a 4-cyl.
Any of you v6'ers have any tricks/tips?
post #5 of 11 (permalink) Old 04-25-2005, 02:26 PM
Axion's Avatar
Quoted: 4 Post(s)
[snapback]398723[/snapback]
Well, next time make note of that so us 4cyl guys wont chime in
Axion is offline
post #6 of 11 (permalink) Old 04-25-2005, 02:43 PM
phishstics's Avatar
who knew?
post #7 of 11 (permalink) Old 04-25-2005, 02:45 PM
Axion's Avatar
Quoted: 4 Post(s)
[snapback]398680[/snapback]
On mine, inside the allen wrench slot, there is a phillips place also, so you can use either or.
Axion is offline
post #8 of 11 (permalink) Old 04-25-2005, 10:13 PM Thread Starter
Bueller? Bueller?
post #9 of 11 (permalink) Old 04-27-2005, 11:58 AM Thread Starter
So am I forever stuck with driving at night with the driverside low beam pointing to the right? Can I buy this tool to reach the cog for the left-right adjustment?
post #10 of 11 (permalink) Old 04-28-2005, 10:01 AM
Not to be a smartass, but go talk to your local service department. See if you can get a rep/service writer to get the tool from the tech to adjust it quickly.
Also, is your driver's low beam pointing substantially to the right? It should point off to the right a bit anyway so as not to blind oncoming drivers. Just a thought...
Indy MPS6 is offline
