Fuse Help needed - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 1 (permalink) Old 04-12-2005, 06:44 PM Thread Starter
yepandIluvit's Avatar
Send a message via AIM to yepandIluvit
Hello, i installed some LEDs, what i did to install them was run + and - wires straight from the battery to a switch and then ran wires from the switch to each light, the lights are meant to recieve power straight from the battery, everything works great but for safetys sake i want to run a fuse on the wires before they get to the switch so i don't go screwing up my 6....anyone have any idea what type of fuse i would need? originally i tried getting the power from a 15 fuse used for the radio but kept blowing it so i simply hooked it up straight to the battery. the switch has a 20amp max and once again everything WORKS! I just want to know what type of fuse to put inbetween the battery and the switch. thanks
yepandIluvit is offline
