Need help asap - fog light relay - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 8 (permalink) Old 04-10-2005, 02:23 PM Thread Starter
BlueGnu's Avatar
Could someone please tell me the part number/ specification for the fog light relay located in the fuse box. I am installing the lower fogs, and noticed that the relay is completely missing!
BlueGnu is offline
post #2 of 8 (permalink) Old 04-10-2005, 03:13 PM
Mazda Gremlyn's Avatar
Do you not have the integrated fogs? I don't have the part number handy, but your dealership parts counter should be able to tell you and order it for you all at once.
2004 Mazda6s MTX: Gone...
Mazda Gremlyn is offline
post #3 of 8 (permalink) Old 04-10-2005, 03:42 PM
Noble's Avatar
Are these fogs the OEM Fog Lights for the Non Sport model?
- if so, the fuse relay in the fuse box is a dummy (a filler piece), the kit comes with a fuse of its own with a relay for the wiring.
On the Sport Models, with integrated fogs, the fuse in the fuse box is real.
2004 6i Onyx Black
Done: Lower Fogs installed, Fog Light Mod, Interior LEDs/Bulbs, Custom Garmin GPS Mount, Hardwired GPS Adapter, Osrams installed (Fogs/Low Beams), Sports Grille, Factory Lip Spoiler, Brake Light Mod
Soon(er) or Later: Eyelids (As soon as it warms up: Dam you Ohio)
Noble is offline
post #4 of 8 (permalink) Old 04-10-2005, 07:22 PM Thread Starter
BlueGnu's Avatar
ok, stil having trouble. I have a non-sport 6i (no int fogs). I swapped out the stick. ( The normal lights/ blinkers stilll work fine). Then I moved the y/g connector up one, and spliced the green wires together. I spliced the wires which were of the same gauge/ color as the jumper. I then attached the positive lead (the one with the fuse) to the fuse box positive, and the negative to the ground. Next, I mounted everything. The fogs do not work. I found a relay at the auto store, and put a 15 fuse in the fog spot.
Any more suggestions?
BlueGnu is offline
post #5 of 8 (permalink) Old 04-10-2005, 08:38 PM
dream weave's Avatar
did you have your headlights on, the wiring you put in place doesn't get activated until your low-beams are on
no more 6
dream weave is offline
post #6 of 8 (permalink) Old 04-10-2005, 09:47 PM Thread Starter
BlueGnu's Avatar
Fixed, it. I had the jumper connected to the wrong light green wire on the lower connector. One last question. For those of you with the non-sport 6i (no integrated fogs), when you added the lower fogs, does the fog icon in the dash illuminate when the fogs are on? Mine does not.
BlueGnu is offline
post #7 of 8 (permalink) Old 04-10-2005, 11:05 PM
no icon for me
no more 6
post #8 of 8 (permalink) Old 04-10-2005, 11:08 PM
I have no icon and I'm stock with fogs.
