having spare key made - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 17 (permalink) Old 04-07-2005, 09:56 PM Thread Starter
Smile
anybody know how to get it done cheaper, why does it take one hour labor to make a key?
mylevy is offline
post #2 of 17 (permalink) Old 04-07-2005, 11:11 PM
vt_hokie2008's Avatar
Send a message via AIM to vt_hokie2008
because it has a chip in the key. you could buy one on ebay specifically for a mazda6 i guess and then program it yourself, which i think someone here or on 6tech should know how to do.
vt_hokie2008 is offline
post #3 of 17 (permalink) Old 04-07-2005, 11:16 PM
Mazda Gremlyn's Avatar
My salesman told me $35 for a new key to be cut.
2004 Mazda6s MTX: Gone...
Mazda Gremlyn is offline
post #4 of 17 (permalink) Old 04-08-2005, 08:25 AM Thread Starter
anybody know how to program a key?
mylevy is offline
post #5 of 17 (permalink) Old 04-08-2005, 09:02 AM
BlueGnu's Avatar
Is it similar to programing a remote? If so it is some combination of putting them in the car, turning the key to the on position, and hitting the door lock.... While patting your head and rubbing your stomach. But seriosly, if it is like the remote, there should be instructions in an old post here or at 6-tech.
BlueGnu is offline
post #6 of 17 (permalink) Old 04-08-2005, 09:11 AM
gr8almty1's Avatar
Send a message via AIM to gr8almty1 Send a message via MSN to gr8almty1
if your paying that much you might as well get the alarm button with the key that flips out. i'm told those are a rx8 key that can be cut for a 6
2005 MAZDA6 s Sports Sedan, Sports Model
Stubby Antenna | 18% Llumar Tint | Debadged
gr8almty1 is offline
post #7 of 17 (permalink) Old 04-08-2005, 06:42 PM
Send a message via AIM to cbob
you need 2 good keys in order to program it yourself. Otherwise, the dealer has a SST for it.
Someone correct me if im wrong tho.
03 6i MTX. 215/55-16 Kumho ASX, EBC green stuff, custom scored/fracturing rotors. Gutted airbox, crank mod, RPM short throw adapter, 2wheelin's fan mod. Sylfex aux-mod, concealed XM install, brake light mod, Redline 75w-90, Redline water wetter, and speed bleeders.
a half dozen UOAs. Currently on ~10k OCI.
suspect vacuum leak issue.
Note to self: no more adjustable wrenches.
cbob is offline
post #8 of 17 (permalink) Old 04-09-2005, 12:54 AM
I only paid $18 for a key and they cut it for free. I programmed it myself. It only took me less than a minute to program it. I wrote the instructions down somewhere I have to find it. I'll post it once I find it.
amy504 is offline
post #9 of 17 (permalink) Old 04-09-2005, 01:04 AM
You need 2 keys to program the 3rd one.
Programming Instructions:
1. Using key 1, turn the ignition to ON position and observe illumination of the security light.
2. After the security light turns off (about 3 secs), then turn the key to the LOCK position within 4 secs and remove it.
3. Repeat steps 1 and 2 with key 2.
4. Repeat steps 1 and 2 with key 3 (key to be programmed)
5. If the security light stops blinking after 3 secs after being on the ON position; it works.
amy504 is offline
post #10 of 17 (permalink) Old 04-09-2005, 02:28 AM
Good find amy, we'll have to document this somewhere so its more easily accessible.
