Mazda Remote Start - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #11 of 20 (permalink) Old 04-10-2005, 09:14 PM
Mazda Gremlyn's Avatar
Originally posted by texn@Apr 5 2005, 09:45 PM
They will only work on the ATX, that is the law.*
I had the dealer install an after market on my 6s when I bought it.* Works like a champ.....
[snapback]388863[/snapback]
I disagree, its not illegal here for an MTX to have a remote starter.
2004 Mazda6s MTX: Gone...
Mazda Gremlyn is offline
post #12 of 20 (permalink) Old 04-10-2005, 09:50 PM
Da 6's Avatar
Send a message via AIM to Da 6 Send a message via Yahoo to Da 6
it's more of a liability with the shops installing it on a MTX since majority of the people I know leave the car in 1st or reverse in the eventthe E brake gave out. Does the 6 have a neutral start switch or clutch in required to start it?
dream weave let me know cause if it's plug and play i'm getting it!
2013 Black Granite Metallic Chevy Cruze Eco 6MT (DD)
2005 Satin White Pearl Subaru Legacy GT (Project)
2003 Lapis Blue Metallic Mazda 6i (Traded In)
Da 6 is offline
post #13 of 20 (permalink) Old 04-16-2005, 01:48 PM
Da 6's Avatar
any updates for the kit?!
Mazda part number 0000-8F-H02 for the sedan
Da 6 is offline
post #14 of 20 (permalink) Old 04-16-2005, 08:51 PM
dream weave's Avatar
install update:
got it all wired in, and still can't get it to work. wiring it in was not the difficulty, I had it done in a couple hours. There are a number of tough spots on the install.
1)steering column. first wiring to do, remove the steering coumn plastic. there's a y connector for the large harness on the left hand side. It takes alot of shifting around in there to get it close enough for the plastic to go back on, still didn't fit right,
2)Factory alarm removal. Small box located on right side of center console. Was supposed to remove the harness, tap into one wire, and leave the harness unplugged. It was a push button harness that didn't want to release, after 10 minutes of tryin to release it, I just pulled and removed the box, don't need it after the install anyways.
3)Power Door Lock Controll) box is located up on the passenger side, up and to the right of the glove box, had to use a screw driver to pop out the harnesses, tap into 2 wires on one harness, plug it back in, and then plug in another y connector.
I have plenty of experience wiring in stereos, this is my first new car and was taking my time, and just can't get the car to accept the new transmitters. I have it wired in completely, and have issues with the alarm going off at. I unplugged the harnesses until I take it to the dealer on thursday for them to finish it, I had to undo the y harness so I could start the car to use until then.
Conclusion) Easy to wire in, just couldn't get it to work, spent a couple hours today trying to troubleshoot it. The instructions have no troubleshooting instructions. Make sure you have a full day to install this if you try this on your own, I'll be putting some pics on my sounddomain page to show some of the wiring.
no more 6
dream weave is offline
post #15 of 20 (permalink) Old 04-16-2005, 08:57 PM
00000's Avatar
[snapback]390918[/snapback]
compustar has a manual safe model starter/alarm combo
i have it on my mtx 6, in order for u to remote start, u will have to set a reservation mode before u shut off the engine
SOLD 04 Mazda6 GT V6 on 19
00000 is offline
post #16 of 20 (permalink) Old 04-17-2005, 02:19 PM
Da 6's Avatar
I don't wanna pay someone to do this! wasa ther batteries in the key fobs? did you use the programing how-to on this site for the key fobs?
Da 6 is offline
post #17 of 20 (permalink) Old 04-17-2005, 08:28 PM
there is batteries in the key fob, on the first try I could get it to unlock the doors and pop the trunk, but that was it.
I used the directions in the install instructions to program in the key fobs, it seemed rather odd to me. I had to have a key in and in the "run" position when I hooked the negative back up, then had to switch to off, then start the car and shut it down. ran into a problem sometimes because it wouldn't turn over, didn't even try. after you get it to start you are supposed to do a two key procedure, this plans the immobilizer interface.
1. Insert key one, turn to run until the security light comes on
2. Within five seconds, repeat with key two
3. Within five seconds, press the lock button then the start button, you should get a confirmation chirp and a parkling light flash, and then start the car.
I'll give it another try tomorrow before I say f it and have the dealer finish it.
no more 6
post #18 of 20 (permalink) Old 04-17-2005, 09:00 PM
These I've resized, if anyone wants I have the full size ones (2048x1560)
no more 6
post #19 of 20 (permalink) Old 04-18-2005, 12:11 PM
[SIZE=14]Success!!!![/SIZE=14]
[SIZE=1]Will post a how to this afternoon[/SIZE=1]
no more 6
post #20 of 20 (permalink) Old 04-22-2005, 06:26 PM
travis0385's Avatar
Send a message via AIM to travis0385 Send a message via Yahoo to travis0385
back to the original post...... the 'mazda' remote start says its for 04+ and you say you have an 03... as do i.... if this is just a technicality and it can be used on the 03 model i want it bad!!!!!
2003 Mazda6i Speed Yellow
Appearance Package, ATX, Fogs, Injen CAI, 25% Tint, Sport Grille, Red Painted Calipers, Mazda Mp3 Player, Audiobahn 8000T amp powering two Alpine SWR-1222ds fiberglassed, Inverted Blacklight Parking Lights, Detailed Engine Cover, 18" Graphite Konig Troubles
travis0385 is offline
