Luminics Bulbs 5,150k VIDEO (streetunit.com) - Page 4 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #31 of 114 (permalink) Old 03-18-2005, 11:43 AM
Send a message via AIM to cbob
2 questions:
1. In the beging of the video, was it your parking lights only, then you turned on the headlight, or was that the headlight then high beam?
2. Can you give me an estimate of how much further you are able to see at night? I've been considering switching out the stockers/getting the lower fog lights (non sport) for a while because I spend I spend ~15 hours/month on unlight 2 lane desert roads, and the stock bulbs don't quite cut it.
03 6i MTX. 215/55-16 Kumho ASX, EBC green stuff, custom scored/fracturing rotors. Gutted airbox, crank mod, RPM short throw adapter, 2wheelin's fan mod. Sylfex aux-mod, concealed XM install, brake light mod, Redline 75w-90, Redline water wetter, and speed bleeders.
a half dozen UOAs. Currently on ~10k OCI.
suspect vacuum leak issue.
Note to self: no more adjustable wrenches.
cbob is offline
post #32 of 114 (permalink) Old 03-18-2005, 02:46 PM
rockandroll's Avatar
i think im gonna get these.... they look incredible. Just one question though... do the H1s replace all 4 bulbs in the headlight housing? I thought there were different bulbs for the fogs (in the housing, not in the bottom of the bumper), and highbeams--Im not too light savvy...maybe the fogs and the highbeams are the same, but I do know that there are 2 different sets of lights for each single housing, and was wondering if these H1s cover both of these bulbs. If not, what do I use for the other bulb to match up? Thanks for the help... i wanna order these as soon as possible, haha.
For Sale: Auto EXE Replica Onyx Black Grille--Check Link Below
rockandroll is offline
post #33 of 114 (permalink) Old 03-18-2005, 04:36 PM Thread Starter
blackmagik_13's Avatar
t mo t, yes the lowered price is still on through his website if I'm not mistaken.
cbob, in the beginning where I pull into the parking lot, just my low beams were on. Then when it gets brighter, that's my highs.
Estimate on sight at night : A hell of alot better ! If I remember to take my camcorder w/ me, I'll get some shots of me driving on the dark interstate back from work on Sun. night.
Rockandroll, yes the H1's replace all 4 bulbs, both Low Beams, and both High Beams.
There are different bulbs in the integrated fogs, they're H3's.
blackmagik_13 is offline
post #34 of 114 (permalink) Old 03-18-2005, 06:00 PM
what would be some good h3s to pair up with these h1s so that itd match?
post #35 of 114 (permalink) Old 03-18-2005, 06:00 PM
techzilla627's Avatar
Ok, there is clicking whenever i turn on the lights. Is that normal?
edit: after using the search feature (what a godsend) i have found out that when i turn on the lights the clicking is from the relay in the fuse box. man, it took me an hour to try to and "fix" it, but its all good now. i guess i never turned on the lights when the engine wasnt off, thus making it impossible to hear the click.
These headlights freaking rock now. what a difference from stock, the lowbeams and the highbeams. now i need to get some h3's for the integrated fogs.
techzilla627 is offline
post #36 of 114 (permalink) Old 03-18-2005, 06:07 PM
leftyrev's Avatar
[snapback]379801[/snapback]
they have h3's also
leftyrev is offline
post #37 of 114 (permalink) Old 03-18-2005, 06:11 PM
^^ah, k, thanks... 1 last question, haha... so would i need 1 pair of h1s and 1 of h3s, then id be good to go? Or do i need two pairs of h1s and 1 pair of h3s? I would think id need just 1 pair of h1s, and 1 of h3s, but i keep hearing people talking about 2 pairs of h1s, and I just want to be sure
post #38 of 114 (permalink) Old 03-18-2005, 11:52 PM
Pulszar's Avatar
[snapback]379808[/snapback]
You need one pair of H1s for the low beams, another pair of H1s for the hi beams, and a pair of H3s for the fogs. So if you are doing a complete lighting overhaul, order 2 pairs of H1s and a pair of H3s.
Im off to order mine now. I have a low beam light out and I figure for $22, that will hold me over till I order my HIDs
Pulszar is offline
post #39 of 114 (permalink) Old 03-18-2005, 11:56 PM
Axion's Avatar
Quoted: 4 Post(s)
I just ordered my HID's tonight or I would have gone with these, still might for the H3 fogs... wonder how close it will be to a 6000k hid though?
Axion is offline
post #40 of 114 (permalink) Old 03-18-2005, 11:58 PM
leftyrev's Avatar
heres is what you need
1 set of H1's for High beams
1 set of H1's for low beams
1 set of H3's for Fog lights
so if you want to replace all your lights , you need to order 3 sets of bulbs ,
you get 2 bulbs in a box
leftyrev is offline
