Winshied wipers sometimes do not work? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 5 (permalink) Old 03-13-2005, 08:41 PM Thread Starter
Once in a while the wipers or wash does not work. Car only has 8000 miles on it. Of course its when you need them that they dont work. Dealer states they cannot replicated problem and will not do anything. Just wondering if anyone else has had this happen to them...thanks
krazyzx9 is offline
post #2 of 5 (permalink) Old 03-14-2005, 04:03 AM
Send a message via AIM to cbob
This might sound stupid, but is there water in the resivor?
03 6i MTX. 215/55-16 Kumho ASX, EBC green stuff, custom scored/fracturing rotors. Gutted airbox, crank mod, RPM short throw adapter, 2wheelin's fan mod. Sylfex aux-mod, concealed XM install, brake light mod, Redline 75w-90, Redline water wetter, and speed bleeders.
a half dozen UOAs. Currently on ~10k OCI.
suspect vacuum leak issue.
Note to self: no more adjustable wrenches.
cbob is offline
post #3 of 5 (permalink) Old 03-14-2005, 08:13 AM
Ericzoom's Avatar
[snapback]377161[/snapback]
Is it that there not turning on at all,or just not wiping good? I've read a lot of complaints about how shitty the wipers are. I also had to change the blades when the car was new because they streaked so bad.
04' 6S ATX cooler,airbox mod
Ericzoom is offline
post #4 of 5 (permalink) Old 03-15-2005, 12:51 AM Thread Starter
Originally posted by Ericzoom@Mar 14 2005, 07:13 AM
Is it that there not turning on at all,or just not wiping good?* I've read a lot of complaints about how shitty the wipers are. I also had to change the blades when the car was new because they streaked so bad.
[snapback]377372[/snapback]
Yes, fluid in the resivor. Not a wiper issue either. They just do not turn on sometims. Sounds messed up and it is!
krazyzx9 is offline
post #5 of 5 (permalink) Old 03-15-2005, 02:04 AM
Well, there should be a connector and motor that sits in/by the bottom of the resivor. Maybe you're having an intermitent problem due to the connector being loose or something.
Sorry to say, but it seems like an electrical gremlin.
bob.
cbob is offline
