Low-Beams Went out! HELP! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 10 (permalink) Old 02-21-2005, 10:46 PM Thread Starter
VAN~MZD~6's Avatar
Send a message via AIM to VAN~MZD~6 Send a message via MSN to VAN~MZD~6 Send a message via Yahoo to VAN~MZD~6
Smile
I recently changed out my bulbs with some new ones...and everything was working fine the day I put them in...Well I didn't drive that night, but tonight when I went for a drive, I didn't have low-beams...
I got home and looked under the hood...the bulbs were fine...switched in the old ones...so the bulb wasn't out...
I checked the fuse, that wasn't blown...
and I checked the connection to both headlights...and they were secure...
Any ideas? Please help...I am still under warranty, but want to try avoid going back to the dealer, and I have to go out of town Sunday...so I need this fixed by then...please lend me any ideas you might have to fix my problem....Thank you!
P.S. Yes my fogs work...my high-beams work...my side markers...and parking lights...only the low-beams are out!
'04 6i Steel Grey ATX 5-Door
EXTERIOR: American Racing | Anzo | G2 | Mazdaspeed | PIAA | Silverstar | Toyo | Visual Garage | Custom Work
INTERIOR: Autovation | MOMO | Shaun Daurbie Custom | Streetglow | More Custom Work
PERFORMANCE: B&M | Hawk | Injen | Kartboy | Magnaflow | Mazdaspeed | PCP | Tokico
AUDIO: Eclipse | JL Audio | Metra | SIRIUS | TotallyCustomAudio®
VAN~MZD~6 is offline
post #2 of 10 (permalink) Old 02-21-2005, 10:48 PM
Axion's Avatar
Quoted: 4 Post(s)
What bulbs did you throw in as replacments and what was the wattage on them?
Axion is offline
post #3 of 10 (permalink) Old 02-21-2005, 10:51 PM Thread Starter
VAN~MZD~6's Avatar
55W....
post #4 of 10 (permalink) Old 02-21-2005, 11:29 PM
FICHSTIX's Avatar
You put the stock bulbs in and they did come on? or did not come on?
When you have a bulb blow out its not all ways in a area that you can see with
your eyes. I've had two blow out and they still look good from sight. If stock did not come on I would buy stock bulb and try before going to dealer. This way you
know for sure.
><((((º>`·.¸¸.·´¯`·.¸.·´¯`·...¸><((((º>¸.
·´¯`·.¸. , . .·´¯`·.. ><((((º>`·.¸¸.·´¯`·.¸.·´¯`·...ZOOM-ZOOM!!><((MS6))º>
FICHSTIX is offline
post #5 of 10 (permalink) Old 02-21-2005, 11:40 PM Thread Starter
VAN~MZD~6's Avatar
I tried not only the bulb that was in there...but one other set of H1&#39;s I have...I think they are Eurodezigns...and I also tried the stock bulbs...none of which came on!
&#39;04 6i Steel Grey ATX 5-Door
post #6 of 10 (permalink) Old 02-21-2005, 11:43 PM
Axion's Avatar
Quoted: 4 Post(s)
You sure you checked all the fuses and everything? It&#39;s gotta be a fuse, if the bulbs were 55watt then you shouldnt have to worry about doing any damage to the H1 wire harness..
Axion is offline
post #7 of 10 (permalink) Old 02-21-2005, 11:46 PM
If you&#39;ve tried the bulbs, reconnected the harness and checked all related fuses, you should go to the dealer immediately, especially if you are going out of town this coming weekend.
Indy MPS6 is offline
post #8 of 10 (permalink) Old 02-21-2005, 11:48 PM Thread Starter
VAN~MZD~6's Avatar
Should I put all my stock bulbs back in before I take it to a dealer? Meaning will having aftermarket bulbs void my warranty and the headlights?
Sorry I haven&#39;t had to take anything back to the dealer before...so I am not sure if changing the bulbs would void the warranty...since in the manual it says to take to an authorized dealer to change the headlight bulbs.
post #9 of 10 (permalink) Old 02-21-2005, 11:51 PM
Axion's Avatar
Quoted: 4 Post(s)
Yes replace them all with stockers and don&#39;t mention anything about replacing them, lol.. otherwise they can say you screwed something up blah blah.. i went through this on my old car and the DRL system screwing up cuz of my 85watt bulbs (stupid choice)..
Axion is offline
post #10 of 10 (permalink) Old 02-22-2005, 06:40 PM Thread Starter
VAN~MZD~6's Avatar
Figured it out...turns out the bulbs weren&#39;t getting a good ground...and the new ones from autolumination were already burnt out
