An Interesting Note on Mazda6 Projectors - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 3 (permalink) Old 02-17-2005, 08:40 PM Thread Starter
This is just an observation I made recently while replacing some bulbs in my headlights. If you open your hood and wipe off the grime that has doubtlessly accumulated on top of your headlight assemblies, you can see that the bulb type is actually imprinted in the plastic above each light. Over the high beam is "H1," over the fog beam is "H3," and over the low beam is...
"H1 or D2S"
Now, I only point this out because there has been a lot of discussion in this forum about "our projectors are not suited for HID retrofit, etc." While I am not discounting others' knowledge of the physics of lighting, there does seem to be some indication that our stock projectors ARE at least somewhat suited to HID bulbs (although a Bosch projector would still undoubtedly look better). I installed H1-based HIDs in my 03 6i and have been very satisfied with the end result.
If this is an old observation that was made months ago, let me know
Zoom Zoom
ChicagoSix is offline
post #2 of 3 (permalink) Old 02-17-2005, 09:08 PM
deedub35's Avatar
Originally posted by ChicagoSix@Feb 17 2005, 07:40 PM
"H1 or D2S"
From all the information that I have gathered the 6 headlight assembly can indeed accommodate two different projectors. The first is the standard halogen projector which uses H1 bulbs. The second is the Bosch e46 HID projector which uses D2S bulbs. The assembly also has the mounting holes for the ballast and a knock-out hole for the wiring. Regardless, the fact remains that D2S bulbs will NOT fit the standard halogen projector.
deedub35 is offline
post #3 of 3 (permalink) Old 02-17-2005, 10:26 PM
MZBuckeye's Avatar
I have noticed this as well. From what others have show us, I think it's safe to say that the assembly says H1/D2S both on it because both H1 and D2S projectors fit and have mounting locations built in. In other words, the headlight assembly will accept both types of projectors. However, this does not mean (to me, anyway) that the H1 projector is designed to house a HID bulb. There are design and manufacturing differences between the two. IMO, the only way to go is the retrofit, although I have not seen the H1 projector with a conversion kit in person yet. The retro only costs about $100 extra to do it right though.
MZBuckeye is offline
