Autolumination 5-led 194's - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 3 (permalink) Old 12-19-2004, 03:55 PM Thread Starter
Send a message via AIM to m6silverbullet
I was attempting to install Autolumination 5-Led 194's into the headlight. You can find them here: AUTOLUMINATION. They seem a bit wide to fit through the opening in the headlight for the 194, but I pushed it through and unfortunately it fell inside the headlight (bastards). I was able to get a wire wrap inside the headlight and got the LED to fall down into the rear part of the headlight, where it remains indefinetly (unless someone can tell me how to get it out other than through the plastic snap-in covers). Has anyone successfully installed these lights? I will post pics of them fully installed when I get the LED out of my f'ing light. It does look good when installed, but you may need a piece of tape to secure the LED in the socket so it doesn't fall into the headlight. Any help would be appreciated. THANKS.
m6silverbullet is offline
post #2 of 3 (permalink) Old 12-19-2004, 06:09 PM
Jax6S's Avatar
It's been my understanding that the largest light you can put there is 4 LEDS. I have 4 LEDS in my parking light myself.
Goodluck with your install. Let us know if it's successful.
2006 Black Mazdaspeed6
Jax6S is offline
post #3 of 3 (permalink) Old 12-19-2004, 10:03 PM
QuiQsV6's Avatar
Send a message via AIM to QuiQsV6
5 or 6 LED's from autolumination won't fit. Only the 6 LED's from superbrightleds.com will fit as they are a tiny bit smaller then the ones from autolumination. You got to make sure you order the right one though as they also have the 6 LED in the same size that autolum. has.
<span style=\'color:red\'>Ryde or Die QuiQ!!</span>
</span>
<span style=\'color:red\'>October&#39;s 6 of the month.
QuiQsV6 is offline
