headlight - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 6 (permalink) Old 12-09-2004, 10:47 PM Thread Starter
my passengers side headlight is not working.. i put two new bulbs and it still wont turn on...my fogs work and my parking..its just my main headlight that wont turn on ..drivers side all lights work....any idea wht it might be..and can i fix it myself...thanks alot
silver6ix is offline
post #2 of 6 (permalink) Old 12-10-2004, 08:54 AM
Jax6S's Avatar
Did you try swapping the driver's side and the passenger's side bulb? If it's still not working, most likely you have bad wire or connector.
2006 Black Mazdaspeed6
Jax6S is offline
post #3 of 6 (permalink) Old 12-11-2004, 08:42 PM Thread Starter
Originally posted by Jax6S@Dec 10 2004, 05:54 AM
Did you try swapping the driver's side and the passenger's side bulb?* If it's still not working, most likely you have bad wire or connector.
[snapback]334016[/snapback]
------------------------YES I TRIED THAT AND IT STILL DOESNT WORK..IS THERE ANY POSSIBLE WAY I CAN FIX THIS..OR IF I TAKE IT TO THE DEALER DO U THINK THEY WILL CHARGE ME ALOT
post #4 of 6 (permalink) Old 12-11-2004, 08:46 PM
Jax6S's Avatar
is it still under warranty?
Jax6S is offline
post #5 of 6 (permalink) Old 12-21-2004, 12:11 AM
NoWeyOut's Avatar
Send a message via AIM to NoWeyOut
check all your fuses. I blew a fuse installing a neon light in the trunk and my whole car wouldn't start. check the fuses in the engine and in the cabin.
03 6s
FS:
FS:
NoWeyOut is offline
post #6 of 6 (permalink) Old 12-21-2004, 11:20 AM
QuiQsV6's Avatar
Send a message via AIM to QuiQsV6
Originally posted by NoWeyOut@Dec 21 2004, 01:11 AM
check all your fuses.* I blew a fuse installing a neon light in the trunk and my whole car wouldn't start.* check the fuses in the engine and in the cabin.
[snapback]338143[/snapback]
Damn, i'm stoopit! I didn't even bother to check the fuses in the engine bay! That might be the cause of my problem with my foglights.
Does anyone know if the lights have seperate fuses for the lights as in one for the integrated fogs and one for the headlights?
If they do then I'll have to check that out. If they don't and they are both off the same fuse then most likely that's not my problem and I'll still have to take it to the dealer.
<span style=\'color:red\'>Ryde or Die QuiQ!!</span>
</span>
<span style=\'color:red\'>October&#39;s 6 of the month.
QuiQsV6 is offline
