HID Ballast Mounting/Wiring Harness/Fuse - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #11 of 12 (permalink) Old 10-13-2004, 09:50 AM
MZBuckeye's Avatar
Hey scans, did you have to put the car up on ramps or jackstands to remove that bumper? Also, what do you think of the color of the lights? I'm torn between 4000ish K, 5000K, 6000K, I just can't decide! I just want it to look factory installed. Thanks, and btw, nice job on the head unit install.
MZBuckeye is offline
post #12 of 12 (permalink) Old 10-13-2004, 11:22 AM
scans007's Avatar
Send a message via AIM to scans007
Originally posted by MZBuckeye@Oct 13 2004, 01:50 PM
Hey scans, did you have to put the car up on ramps or jackstands to remove that bumper?* Also, what do you think of the color of the lights?* I'm torn between 4000ish K, 5000K, 6000K, I just can't decide!* I just want it to look factory installed.* Thanks, and btw, nice job on the head unit install.
[snapback]315090[/snapback]
If you click on my Sig, and look at page 6 you will see the color of the lights and see that the car is just on the garage floor with no lifts.... I just slid a small peice of carpet to rest my bumper on when lowering it, then uncliped the side marker lights and moved it completely out of the way. and used a recycle'n bin to prop under the lights when work'n on them. No need for ramps as long as you have a short screwdriver....
As for color............Def go with the 5k.....it's perfect....I think the 4000k wouldn't be enough for me...5k def is pure white...with the slightest hint of blue really not noticeable to the naked eye.......5k very OEM high end car look'n when installed. 6k def wouldn't be good for ya if you wanna stay stock look'n....I was between 4 and 5....I'm glad I went with the 5........but of course all IMHO
NEW:
|OLD: 04 Steel Gray 6s -- KEEP ON 6'N
scans007 is offline
