electrical problem? need help - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 4 (permalink) Old 09-17-2004, 08:25 AM Thread Starter
does anyone have a slight problem with there turn signals. for some reason, my right front turn signal won't flash during certain times. i will first notice it when i deactivate my alarm system and the right front turn signal won't flash. and when i get into the car and test my turn signal, it makes a fast clicking sound. here's the weird part, though, the turn signal will work fine as soon as put my car into drive. it doesn't malfunction all the time and i only seem to notice it when it rains. any idea what the problem is?
sevenfinches is offline
post #2 of 4 (permalink) Old 09-17-2004, 09:21 AM
dawei213's Avatar
It's a documented problem. Take it to the dealer.
http://forum.mazda6club.com/index.ph...opic=11435&hl=
dawei213 is offline
post #3 of 4 (permalink) Old 09-17-2004, 09:28 AM
M6SLover's Avatar
maybe it has something to do with the daylight lamps. when you put ur car in drive the daylight running lamps/head lights come on right? i think they could have something to do with this. do this .. turn your car on .. trun on the headlights (do not shift gears, leave it in park) and try the signals .. then you will know. not sure how to fix it though. if you have warranty take it to dealer, if not take it to walmart .. they'll fix it real cheap. just a thought ..
M6SLover is offline
post #4 of 4 (permalink) Old 09-17-2004, 09:42 AM Thread Starter
hey man, thanks for the help. just read the posts. funny, it seems there are several different ideas on what the problem/solution is. hopefully, the dealer here will know how to fix it. i'm gathering that the connectors/housing is the problem...?
