Ignition wire - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 2 (permalink) Old 08-09-2004, 02:11 AM Thread Starter
Does anyone know where the ignition wire is located to detect when the ignition is on/off? Also what color is it? Thanks.
amy504 is offline
post #2 of 2 (permalink) Old 08-11-2004, 04:15 AM
6iGuy's Avatar
The ignition wire is located at the ignition switch harness inside the plastic housing behind and below the stering wheel (the part where your key goes in). I believe there are three screws to take out and then you will have to separate the top and bottom plastic pieces. The wire you are looking for is blue.
6iGuy is offline
