Green "Headlight on" indicator light and electro-gauge nighttime intesity sett - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 21 (permalink) Old 05-18-2004, 06:04 PM Thread Starter
itbeanew1's Avatar
Send a message via AIM to itbeanew1 Send a message via MSN to itbeanew1 Send a message via Yahoo to itbeanew1
Green "Headlight on" indicator light and electro-gauge nighttime intesity settings
I have read on here that a lot of you are annoyed by the green "headlight on" indicator. I WAS too. What really annoyed me though is that with the lights on, you only have two options for the brightness of the electrolumescent gauges,,, either REALLY dim, or whatever they are set on for daytime (really bright for me). I wanted to have all the coices in brightness at night that i do in the daytime, so i figured cut the wire going into the gauges that tells the cluster your lights are on. I found it by looking at the wires going to the dimmer switch for the dash lights. It is green with a red stripe. Just a snip and some tape over exposed wires and presto, (lol) no more green headlight on indicator light (which we dont need cause they turn off automatically and we can just look at the switch), I have the same brightness level choices as i do without the lights being on, and, as an added bonus, I dont have the lights on buzzzzzzzzzzzzzzzzzzzzzzzz telling me the lights are on. The door opened chimes are still there.
Hope some of you might find this info usefull.
Blazing Copper 04 6s MTX Sedan
Custom interior ambiant lighting, Airbox Mod (sometimes), Mazdaspeed6 tails, custom installed lower fogs (burnt out. need to get the kit)
RIP
itbeanew1 is offline
post #2 of 21 (permalink) Old 05-18-2004, 07:56 PM
Reading Topic: Green
our lights turn off automaticly when left on?
2004 Mazda 6s MTX
cp-e intake / magnaflow / eibach pro / Toyo T1-S / KartBoy Exhaust Hangers
email:
FAQ:
Interior Trim Paint Code:
Ford Color Code: M4616J
Cyber_Drone is offline
post #3 of 21 (permalink) Old 05-18-2004, 08:11 PM Thread Starter
itbeanew1's Avatar
yep. give them like 30 seconds or so
RIP
post #4 of 21 (permalink) Old 05-18-2004, 10:03 PM
6-s-5door's Avatar
Send a message via AIM to 6-s-5door
Everything turns off. Interior and exterior. Batt Save feture.
2004 6s 5-Door; loaded
CP-E MafCi (Prototype), Tanabe GF210, Yokohama ES100, Sylfex AuxMod, 35% Tint, RPM Short shifter.
6-s-5door is offline
post #5 of 21 (permalink) Old 05-20-2004, 09:02 AM
mbrogz3000's Avatar
another little feature you may not know...
if you accidently hit the 'unlock' on your keyless pad while the car is locked and nobody opens a door, then the car locks itself again in about a minute...
mbrogz3000 is offline
post #6 of 21 (permalink) Old 05-20-2004, 09:22 AM Thread Starter
itbeanew1's Avatar
That is a cool little feature but can be a pain if you are getting close to the car and unlock it from far away... sometimes when you get to the car the doors are locked again. Cooler than not cool tho.
RIP
post #7 of 21 (permalink) Old 05-24-2004, 11:24 AM
Replying to Topic 'Green
Uhmm...
Last time I looked my electroluminesent gauge cluster was infinitely dimable via a rheostat on the dash board. The push switch in the cluster is only used to select between day (full on bright) to night time (dim from full bright to full dark) illumination when the lights are on. System defaults to full bright when the lights are off.
Other than the green light thing, am I misunderstanding something here?
Racer944 is offline
post #8 of 21 (permalink) Old 05-24-2004, 12:35 PM Thread Starter
itbeanew1's Avatar
yea thats right it is, but at the brightest level it was much lower than i would have liked it to be... to me or maybe just my car, i dont know, it was way to dim even with the dimmer turned all the way up. now i can adjust the levels of brightness independent of the rest of the dash lights.
RIP
post #9 of 21 (permalink) Old 05-24-2004, 12:37 PM
falcontx's Avatar
How does this mod affect the LCD display for the radio/AC? When you turn the lights on, does the LCD still dim?
Are you one of our valued customers? Join The RPM Crew today and help spread the word! --
Come check out our website! --
-- We have a huge selection of parts for the Mazda 6 and Mazdaspeed 6!
Like us on Facebook for news and discounts! --
falcontx is offline
post #10 of 21 (permalink) Old 05-25-2004, 08:17 AM Thread Starter
itbeanew1's Avatar
nope it doesnt change how that works at all. Im guessing cause it has its own seperate dimmer override button. i was scared of that too.
RIP
