Green "Headlight on" indicator light and electro-gauge nighttime intesity sett - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #11 of 21 (permalink) Old 05-26-2004, 03:31 PM
JettaJet's Avatar
Send a message via AIM to JettaJet
Reading Topic: Green
How/where do I access this wire to cut it?
JettaJet is offline
post #12 of 21 (permalink) Old 06-03-2004, 03:00 AM
JettaJet's Avatar
Bizzump
JettaJet is offline
post #13 of 21 (permalink) Old 06-03-2004, 10:51 PM
1hot6's Avatar
Quoted: 4 Post(s)
Replying to Topic 'Green
since I have an 04 without the luxary package, I didnt get the luminesent gauges...which isnt cool but whatevr. Also, I dont have the green indicator light but I thought I did in the beginnign when I first bought the car....did mine go out or does it really not come with it and I just made that up?
2004 Mazda6s 5 Speed Manual Lapis Blue Metallic
Current Modifications:
Injen CAI, Magnaflow Catback Custom NO Resonator, 8000K HID Kit from Xenondepot, 20% tint, Brakelight Mod, Grounded TB
1hot6 is offline
post #14 of 21 (permalink) Old 06-04-2004, 12:32 PM Thread Starter
itbeanew1's Avatar
Send a message via AIM to itbeanew1 Send a message via MSN to itbeanew1 Send a message via Yahoo to itbeanew1
Sorry it took so long to get back to you guys. Been busy.
First, JettaJets q...
You have to take the gauge surround off. do this by
Find the 2 screws at the top of the suround holding it on. Remove them.
The bottom is held in by 2 clips... one on each side.
Just pull back on the surround and they will snap out.
Tilt wheel all the way down and telescope it all the way out.
Pull suround out as far as you can and than push it towards the drivers door to sort of
roll it out of the dash. You will see what i mean when you do it.
Once that is out of the way, you will see i think 2 screws holding the gauge cluster in.
take those out and then the gauges are free to be taken out of the dash.
You will see 2 plugs on top of the cluster; one on the left side and another on the
right. the wire you need to cut is on the left plug. it is green with a red stripe.
cut that, tape off exposed wires, and put everything back together the same way
you took it part.
Now for 1Hot6...
I think the green "headlight on" light is only used with the electro gauges because they act pretty independent of the headlights... not like the regular gauges that only light up when lights are on. This way you can easily see if your lights are on. I could be wrong about this though having never driven or been in a car without the electro gauges.
Blazing Copper 04 6s MTX Sedan
Custom interior ambiant lighting, Airbox Mod (sometimes), Mazdaspeed6 tails, custom installed lower fogs (burnt out. need to get the kit)
RIP
itbeanew1 is offline
post #15 of 21 (permalink) Old 06-07-2004, 04:49 AM
JettaJet's Avatar
Nice. Thanks.
JettaJet is offline
post #16 of 21 (permalink) Old 06-29-2004, 02:45 PM
JettaJet's Avatar
itbeanew1, I pulled out the cluster, and I see no green wire with a red stripe on the left side, or the right side. There's a green wire on the left side with an orange stripe. Is that what you meant to say? I don't want to cut anything until I know for sure.
JettaJet is offline
post #17 of 21 (permalink) Old 06-29-2004, 03:57 PM
JettaJet's Avatar
Nevermind. I found the proper wire and cut it. Works beautifully. While I had the gauge cluster out, I went ahead and drilled holes and mounted my LEDs which indicate which, if either, of my aftermarket fog lights are on. They're behind the plastic cover, which gives them a very stock appearance.
JettaJet is offline
post #18 of 21 (permalink) Old 06-29-2004, 04:11 PM
falcontx's Avatar
Reading Topic: Reading Topic: Green
So.... Was it a green wire with a red stripe?
Are you one of our valued customers? Join The RPM Crew today and help spread the word! --
Come check out our website! --
-- We have a huge selection of parts for the Mazda 6 and Mazdaspeed 6!
Like us on Facebook for news and discounts! --
falcontx is offline
post #19 of 21 (permalink) Old 06-29-2004, 05:27 PM Thread Starter
itbeanew1's Avatar
yea it very well could have been orange. its been a while. im not totally sure. is that the one you cut? Im glad it worked out good for you. the lights look good on there like that. I have a few ideas using LED's im about to start working on soon. Ill keep you all posted.
RIP
post #20 of 21 (permalink) Old 06-30-2004, 12:05 AM
JettaJet's Avatar
It was a green wire with a red stripe, just not on the LEFT side. It was on the RIGHT side.
JettaJet is offline
