Auto down for all windows? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 21 (permalink) Old 04-27-2004, 12:28 PM Thread Starter
If you were to replace the other three switches on the drivers door to the same switch as the drivers power window switch, would they all be auto down?
Has anyone tried this?
1999 Isuzu Trooper. Uses oil like crazy.
Ex-Mazda 6s owner. 5spd with hatch the way to go.
bchapman is offline
post #2 of 21 (permalink) Old 04-27-2004, 12:35 PM
Absolut's Avatar
Send a message via AIM to Absolut Send a message via MSN to Absolut
Reading Topic: Auto down for all windows?
My gut feeling is that it wouldn't work by just switching out all the switches to the drivers one. There will be some extra wiring work to get it right.
Besides... mazda says that you shouldn't roll down more than 2 windows at any one time to reduce strain on the motors.
Storm Reports Map:
Absolut is offline
post #3 of 21 (permalink) Old 04-27-2004, 12:38 PM
Your idea won't work. I've already taken apart one switch unit from a door panel I bought off of eBay for this very reason. The circuit for the auto down is on the circuit board for the entire window switch control. It's not like other switches in which the auto up/down is integrated into the switch itself.
Indy MPS6 is offline
post #4 of 21 (permalink) Old 04-27-2004, 01:56 PM
dawei213's Avatar
Replying to Topic 'Auto down for all windows?'
Doesn't each window have their own motors? So the rear passenagers shouldn't roll down the window while you roll down yours? Or do you mean from the driver side control?
dawei213 is offline
post #5 of 21 (permalink) Old 04-27-2004, 03:00 PM
I think he meant the current draw could overload the curcuitry. All the power windows are wired through the same fuse block, the current draw when you are putting down a window is so great your headlights dim ever so slightly.
diesel5599 is offline
post #6 of 21 (permalink) Old 04-27-2004, 04:44 PM
Absolut's Avatar
Correct...
An even easier way to notice is to try putting down all 4 windows at the same time.. It takes a while for them to get down compared to doing them one at a time. While this is probably the case for many new cars... but because Mazda has all 4 windows on the same fuse block it becomes a liability for a fuse to blow if there were auto down for all 4 windows. I would have liked to see driver and passenger auto-down.. but I can live with what I have.
Storm Reports Map:
Absolut is offline
post #7 of 21 (permalink) Old 04-27-2004, 08:17 PM
LapisM6i's Avatar
* * * * * * Correct... *
An even easier way to notice is to try putting down all 4 windows at the same time.. It takes a while for them to get down compared to doing them one at a time. *While this is probably the case for many new cars... but because Mazda has all 4 windows on the same fuse block it becomes a liability for a fuse to blow if there were auto down for all 4 windows. *I would have liked to see driver and passenger auto-down.. but I can live with what I have.
i agree. although i'd like auto up too. but i see the safety hazards it would impose.
LapisM6i is offline
post #8 of 21 (permalink) Old 05-02-2004, 11:51 PM
i want windows with strong enough motors to cut of heads or other body parts that may have been stuck in the window at time of hitting the button. Have a turbo up/down mode for guillotine mode =)
but that's just my sick world
w00pie is offline
post #9 of 21 (permalink) Old 05-03-2004, 12:43 AM
Send a message via MSN to Niveko2k
Benz has auto up and down for all four windows... maybe we can use the circutry from those? if its compatable?
Why won&#39;t my steering be on center? >-<"
Niveko2k is offline
post #10 of 21 (permalink) Old 05-03-2004, 06:21 PM
well i don't have wiring diagram book or know if its even in there, but if the driver side has its own circuit to allow autodown, just buy that circuit board and wire it to the other switches/windows for passenger or what not. I'm sure though that they charge arm and a leg for the boards for those
w00pie is offline
