To those with the XenonFactory HID... - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 12 (permalink) Old 02-16-2004, 12:01 PM Thread Starter
dawei213's Avatar
Let me say this first...installation wasn't that bad, except for trying to get it clamped down. I swore I must've spend like 15 minutes each side just to try to clamp it down. Love the HID though. So much brighter!
Okok, question now... the relay has three metal rings, one right off of the fuse that is use the +, one for the ground (-), and the last one that is wrapped around the end of the big block of wires all joined together. For the last one, is that a ground or is that there so that you can mount it somewhere? I don't have that one grounded but the HID works.
Also, anyone had their lights go off when hitting a pretty hard bump? I was going about 95 or so on the highway when I went over a few nasty spots. My right light gave out. Not wanting to pull over and do anything with the car in the middle of no-where at 2:30 am i drove about 40 minutes to the nearest rest stop (yes, middle of no-where) with only my left HID light operating. I pulled into the stop. Turn my lights off, then right back on and then it's fine. Can anyone explain?? Could the jolt affected the operation of the ballast or the bulb?
On a side note, I was suprise that even with on HID light, it was still brighter than some other car's halogen lights or my old lights... very nice!
dawei213 is offline
post #2 of 12 (permalink) Old 02-16-2004, 12:18 PM
deanobhoy's Avatar
Send a message via AIM to deanobhoy Send a message via MSN to deanobhoy
Reading Topic: To those with the XenonFactory HID...
Congrats on ur HID's
Any excuse to let you see my avatar again as you like it so much lol
Ps the signature police will be paying you a visit soon :)
deanobhoy is offline
post #3 of 12 (permalink) Old 02-16-2004, 12:38 PM
Dawei, that metal piece extending off the relay/switch is just there for mounting purposes. As far as the light going out... I had this happen to me and found out that one of my bolts I used to ground the kit wasn't 100% tight. Try that first because my lights did EXACTLY as you described until I tightened the bolt down.
AKA1sexy6 is offline
post #4 of 12 (permalink) Old 02-16-2004, 05:07 PM
DRAGONS6's Avatar
Also if anyone else has problems closing the clamp, just use some needlenose pliers. Took 5 seconds. :D
(better pics)
and check out myspace
DRAGONS6 is offline
post #5 of 12 (permalink) Old 02-16-2004, 05:32 PM Thread Starter
dawei213's Avatar
Replying to Topic 'To those with the XenonFactory HID...'
Every single time I come across your post I ... :drool
Kyle, I checked and your right, one of my ground was loose. I thought I doubt check everything.
Dragon, yeah I did it for the second one, but not before I spend 15 minutes with my thumb and fingers.
Also, how do you guys lay out the extra wires? How did you guys route the right light to the battery? towards the windshield or the front of the car? Got pics to share?
Oh a side note....I had the right relay wire running across the front of the engine then up to the battery...when i checked the line, I saw it a bit chewed up. F-me! It was getting chewed up by the serpertine belt. Luckily it only chewed up part of the exterior insulation and not the wiring. Got some electrical tape to patch it right back up.
dawei213 is offline
post #6 of 12 (permalink) Old 02-16-2004, 05:34 PM
Driver6's Avatar
* * * * * * Congrats on ur HID's
Oh yeah, he's a really bad boy. :P
I want to die in my sleep just like my grandfather did and not screaming and yelling like his front seat passenger.
Driver6 is offline
post #7 of 12 (permalink) Old 02-16-2004, 05:55 PM
DRAGONS6's Avatar
I tucked the wires as best I could on the drivers side under the fuse box. On the passenger side I ran the wire up by the windshield.
(better pics)
DRAGONS6 is offline
post #8 of 12 (permalink) Old 02-17-2004, 10:41 AM Thread Starter
dawei213's Avatar
Cool, thanks for all the help guys....
dawei213 is offline
post #9 of 12 (permalink) Old 02-17-2004, 12:53 PM
yeah, I ran my passenger side "battery" wire up towards the windshield and under the black plastic piece that is under it. I'll get a pic when i can.
post #10 of 12 (permalink) Old 02-17-2004, 06:56 PM
I openned the front wire looming and thug everything in there. You don'T see anywire in my car. As for the extra wire, I cut everything before wiring it to the relay, pretty easy job. We can call this a home made relay I guess....
But what I like is seing no wire, no ballast, nothing. Looks OEM :)
onepunchx is offline
