Spark Plug & Wires - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 10 (permalink) Old 02-10-2004, 05:52 PM Thread Starter
Spark Plug & Wires
hi need to buy a new Spark Plug & Wires could sombody help on these things ??
whats the best & whats the part or number can i use for my Mazda6i 2.3L ???
thaaaaaaaaaaaaaaanks,,,, ;)
Mazda_Guru2 is offline
post #2 of 10 (permalink) Old 02-10-2004, 06:04 PM
timba24's Avatar
Send a message via AIM to timba24 Send a message via MSN to timba24
Reading Topic: Spark Plug & Wires
Well from what I have heard and remember reading is that the best plugs for these engines are really the stockers. Of course if you used the search button you would have seen that
timba24 is offline
post #3 of 10 (permalink) Old 02-10-2004, 09:38 PM
Gruss's Avatar
Send a message via AIM to Gruss Send a message via Yahoo to Gruss
Replying to Topic 'Spark Plug & Wires'
Shouldnt a mazdaguru already know hte answer? Or are you just testing us?
'03 Mazda6 S
'03 Explorer
'97 VFR
Gruss is offline
post #4 of 10 (permalink) Old 02-11-2004, 10:48 AM
Good set of platniums are probably your best shot. Which I think is what they use for stock.
rrhunt28 is offline
post #5 of 10 (permalink) Old 02-11-2004, 11:23 AM
Why do you "need" to buy new wires and plugs already? How many miles are on your car?
Indy MPS6 is offline
post #6 of 10 (permalink) Old 02-11-2004, 12:00 PM
plugs depend on the motor... on my 94 accord with msd ignition, blaster coil, and 8.5mm msd wires the denso stockers worked best... i go thru a set in a couple of months... in the winter i use bosch platinum plus 4 which lasts the entire winter but is not as good as the non platinum stocker densos... i would stick to the stockers on the MZ6
99YammieR1 is offline
post #7 of 10 (permalink) Old 02-11-2004, 12:15 PM
Toadster's Avatar
so do our motors use the single plats or double plats?
i know the SVT 2.5L uses a Double Platinum plug... Duratec of course :seeya
SOLD 2004 Performance White MAZDA6s MTX
Injen CAI | Magnaflow Catback | CP-E MAF-c | 18% Tint | Red Line MT-90
17x7 Kosei T1 TS Wheels & Continental ContiExtreme Contact DWS 225/45-17
Toadster is offline
post #8 of 10 (permalink) Old 02-11-2004, 04:14 PM
backy51
Guest
Posts: n/a
Quoted: Post(s)
Platinum plugs are only good for longevity. If you're looking for performance just stick with NGK's, they're cheap and perform very well. If you want to spend more money (don't expect much of a difference unless you're boosted or running very high compression which I don't think anyone is yet) then look into iridiums, be it NGK or Denso. Bosch +4's are just a gimmick plug. BTW NGK's are used in all levels of racing, that should point out the qualities of the plug.
post #9 of 10 (permalink) Old 02-11-2004, 04:38 PM
NGKs are good... i use it on my bike plus it's just as good on my accord as the densos
don't use the bosh platinum +4 on a stock ignition
post #10 of 10 (permalink) Old 02-11-2004, 05:04 PM
I want to get a multi spark box with +4's.
rrhunt28 is offline
