Integrated fog lights not working... - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 5 (permalink) Old 01-11-2004, 04:27 PM Thread Starter
Zm_Zm_Saint's Avatar
Send a message via AIM to Zm_Zm_Saint
I replaced my fog bulbs with some discount super whites. The driver side one burned out so I just decided to put my old ones back in. I replaced the driver side one and checked to see if it would turn on, and it did. Then I replaced the passenger side super white with the original but afterwords, neither of the fogs would turn on, I can hear the click when I flip the fog switch but nothing else happens. I disconnected and reconnected both of the wires from the bulbs but still no luck.
Got any ideas to what's up?
Edit: Welp, I just saw that there are spare fuses, so I replaced the fog fuse with the new one, turned the fogs on then the fuse blew...Guess I'll just take it in to my dealership.
Zm_Zm_Saint is offline
post #2 of 5 (permalink) Old 01-11-2004, 05:00 PM
Replying to Topic 'Integrated fog lights not working...'
You have a defective bulb or you are not wired as you should be... You are making a short with the last bulb you changed....
onepunchx is offline
post #3 of 5 (permalink) Old 11-06-2006, 07:32 AM
Send a message via AIM to wattersa81
Any luck with this? I had bought the Xtec bulbs from Donny at RPM and one went out and so he replaced them for free and I noticed the other day they weren't working. I checked the fuse and it was blown, replaced it and it blew again. I was trying to see if I could get some feedback on others who have experienced this prior to digging into the wiring.
wattersa81 is offline
post #4 of 5 (permalink) Old 11-07-2006, 02:49 AM
t_mo_t's Avatar
if you hear the click/flip sound when you turn on something, that's the fuse just blew... check whether any positive is touching the negative... i would check the fog bulb holder.. since the negative is basically connected to the prj IIRC, if your positive is touching it, then there you go... blew fuse...
t_mo_t is offline
post #5 of 5 (permalink) Old 11-09-2006, 09:38 AM
Checked my fog light connections and sure enough, the driverside light was shorting itself so I moved it out of the way tested and they work!
