Climate Control/Fan Smells - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 6 (permalink) Old 12-05-2003, 12:30 PM Thread Starter
NoWeyOut's Avatar
Send a message via AIM to NoWeyOut
it smells bad when i turn on the fan. the a/c is fine. it smells like acid rain/L.A. smog all in one package. i have less than 1K miles on my car. did you guys experience this too? i drive a 6s.
03 6s
FS:
FS:
NoWeyOut is offline
post #2 of 6 (permalink) Old 12-05-2003, 03:05 PM
Replying to Topic 'Climate Control/Fan Smells'
Does it happen all the time? I noticed in this car that if I slip the clutch a bit to much you get this terrible smell that shoots right into the car. I do not get it much now that I am used to the cars clutch and tranny, but when I first started driving it it would happen about every 2 times I took off. LOL
rrhunt28 is offline
post #3 of 6 (permalink) Old 12-06-2003, 03:02 PM
first mazda's Avatar
^^rrhunt, that's normal. You were riding the clutch :(.
As for the smell, I got it. Anytime I used the A/C with the dash vents, it smelled like anus. It was definitely due to the use of A/C because it was absent without. I know that the smell is common when you do things like turn off the car with the A/C running because that supposedly leads to mildew build up (and then the smell). But my car was doing it from the very beginning and I did everything I could to make sure the A/C was off before I ever got home and even "aired" out the vents. Mildew still??
The other funny thing is that you never smelled it when you ran the defroster, which also uses the A/C. That was evident on any slightly chilly summer night but now that it's winter, I almost always use the A/C for defrost puposes (not liek you have a choice in these cars anyway - it's automatic) and I never smell it anymore. Hell, I even switched the A/C on and set it to 60 deg one night witht he dashboard vents - no smell (but I froze my ass off putting my nose up against the vent to smell for anything :().
It might come back when it's warm but that is months away. Maybe it's only with A/C use on cold settings? Dunno. I'm reaching for explanations here...
first mazda is offline
post #4 of 6 (permalink) Old 12-09-2003, 05:16 AM
Rowdy's Avatar
QUOTE
Originally posted by first mazda
* * * * * * ^^rrhunt, that's normal. You were riding the clutch :(.
As for the smell, I got it. Anytime I used the A/C with the dash vents, it smelled like anus...[/b]
I won't touch that quote. :D
Rowdy is offline
post #5 of 6 (permalink) Old 12-09-2003, 01:01 PM
Well, I only mentioned the clutch because I have driven a few manuals in the past, and never have the clutches smelled as bad as this one. I dont know what they make it out of, but it reaks.
rrhunt28 is offline
post #6 of 6 (permalink) Old 12-09-2003, 01:09 PM Thread Starter
NoWeyOut's Avatar
i don't smell burning oil or anything...it jus smells like urinals sometimes. and this does happen when i switch from a/c to fan. so as one of you guys said...it might be the dew from the a/c unit. hopefully it goes away! :)
03 6s
FS:
FS:
NoWeyOut is offline
