Resonator Removal - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 5 (permalink) Old 12-02-2003, 08:00 PM Thread Starter
LapisM6i's Avatar
Resonator Removal
Hey...
I am fully aware that there is a long thread about removing the resonator and the airbox internals etc etc, however when i tried to get in again, the link didn't work....
this is the link:
http://bellsouthpwp.net/s/i/simple_man/Air...box/Airbox.html
does anyone know where i can find instructions to remove the resonator?
thanks.
LapisM6i is offline
post #2 of 5 (permalink) Old 12-02-2003, 11:40 PM
84FordMan's Avatar
Reading Topic: Resonator Removal
I can give you a quick walk through on it:
- Remove the bottom bolts holding the splash guard in place underneath the vehicle on the driver side (10mm if I remember correctly)
- Then unscrew and pull out as many of the fender well splash guard fasteners as required to pull enough of the splash guard out of the way for you to get easy access to the resonator.
- Take same 10mm to the two bolts holding the resonator box in place. Once loosened you can pull down and away from those bolts and it will slide out, or you can completely remove the bolts.
And as alot of our Haynes manuals at work say about any type of repair for reassembly, repeat all these steps in reverse sequence. :)
1994 Mazda B3000 SE
Daily driver
84FordMan is offline
post #3 of 5 (permalink) Old 12-02-2003, 11:54 PM
Not to flame, but I highly doubt this is an electrical topic :P
AKA1sexy6 is offline
post #4 of 5 (permalink) Old 12-03-2003, 09:27 PM Thread Starter
LapisM6i's Avatar
haha yeah i noticed...i was thinkin about grounding when i was posting this, so i put it in electrical. my fault...thanks fordman...and if a moderator can remove it, that'd be great. thanks.
LapisM6i is offline
post #5 of 5 (permalink) Old 12-03-2003, 11:32 PM
Eh, why start now with putting threads in the right section! :D :P
Indy MPS6 is offline
