Led lights - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #11 of 13 (permalink) Old 10-27-2003, 08:30 PM
Reading Topic: Led lights
I'd say give it 3 business days. It is sent through US postal service so it should be in your mailbox when it arrives. When you install LEDs, there is a right and wrong polarity. I suggest installing one at a time, and for each, turn on the lights for a second and see if it lights, if not, immediately turn off switch and pull out the bulb and rotate it 180 deg and put it back in and it should light when you turn on the switch again.
Whyzor is offline
post #12 of 13 (permalink) Old 10-27-2003, 09:24 PM
first mazda's Avatar
Replying to Topic 'Led lights'
QUOTE
Originally posted by Whyzor
* * * * * * I'd say give it 3 business days. It is sent through US postal service so it should be in your mailbox when it arrives. When you install LEDs, there is a right and wrong polarity. I suggest installing one at a time, and for each, *turn on the lights for a second and see if it lights, if not, immediately turn off switch and pull out the bulb and rotate it 180 deg and put it back in and it should light when you turn on the switch again.[/b]
Damn. Thanks for the heads up on the polarity... :) I could see myself sitting there screaming WTF?
first mazda is offline
post #13 of 13 (permalink) Old 10-27-2003, 09:35 PM Thread Starter
yea hehe thanks for all the help whyzor.
JiNeTiC341 is offline
