Running the wire for - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 5 (permalink) Old 10-19-2003, 01:05 AM Thread Starter
atom44wat's Avatar
I want to install some aftermarket fogs to the car, but i have know idea how to run the wire and mount a nice looking switch in the blank. How do you run the wire through the fire wall? Help
maybe some pics can help too!
thanks!
atom44wat is offline
post #2 of 5 (permalink) Old 10-19-2003, 01:08 AM
84FordMan's Avatar
Reading Topic: Running the wire for
Drill?
1994 Mazda B3000 SE
Daily driver
84FordMan is offline
post #3 of 5 (permalink) Old 10-19-2003, 02:14 AM
[iG]'s Avatar
Get something sharp, and poke a hole in it... run your wire through it..
[iG] is offline
post #4 of 5 (permalink) Old 10-19-2003, 02:15 AM
[iG]'s Avatar
take off your battery first, it will give you easier access, and its easier to make the hole from the inside, just follow the wire cluster from under the drivers console and you'll see it...
[iG] is offline
post #5 of 5 (permalink) Old 10-19-2003, 02:44 AM
ZeroEfxs's Avatar
Send a message via AIM to ZeroEfxs Send a message via MSN to ZeroEfxs Send a message via Yahoo to ZeroEfxs
There is a grommet in the firewall on the drivers side, you can access it under the dash, it has a whole lot of wires running through it, you can use a metal coat hanger and run a wire through not hard at all
ZeroEfxs is offline
