Just installed my H1 PIAA Hyper White Bulbs :-) - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 18 (permalink) Old 10-05-2003, 11:47 AM Thread Starter
sick6.com's Avatar
Send a message via AIM to sick6.com Send a message via MSN to sick6.com Send a message via Yahoo to sick6.com
I've tried reading up on some posts in this forum on how to intall the low beam bulbs on the 6 and I wasn't about to take off my bumper just to install two little bulbs ..
On the drivers side all I did was take off the cover for the fuse box and that gave me a 1/2 inch or more give-way to get my fingers in there to do the job. Next very simply took off the circular cap that covers the opening to the bulb. took off the positive and negative connectors off the bulb and then snaped up the clip that holds the bulb in place and pulled it out. Its as simple as that. Just go nice and slow so that you get a good grasp on the bulb so you dont drop it. Next just put the new bulb in (you have to make sure you put it in correctly or the clip wont close) and then close the clip put on the positive and negative the same way you took it off and close it all off with the circular cap and your done !
On to the passengers side !! this was easier .. once you remove 3 bolts that hold the engine coolant you can just move that right out of th way. this gives you a lot of room to work with to take the passengers side low beam out. Follow the same steps as above and then put the coolant container back - and your done.
Here are some pictures of the differences (passengers side - STOCK and drivers side PIAA)
Here's the stock bulb first
Here's the NEW PIAA Hyper White Bulb on the drivers side
Hope this helps and clears some things up! later
Sold my Mazda6 - Currently owner of a 2001 BMW 325ci
sick6.com is offline
post #2 of 18 (permalink) Old 10-05-2003, 06:39 PM
Reading Topic: Just installed my H1 PIAA Hyper White Bulbs :-)
Are they 55W or 100W cause they look insane. If they are 100W, check your cable harness cause one day you will cry for sure...
WiDeFiRE is offline
post #3 of 18 (permalink) Old 10-05-2003, 06:47 PM
Absolut's Avatar
Send a message via AIM to Absolut Send a message via MSN to Absolut
Very informative.. I need to get this done with my sylvanias here soon when I get some time! Hopefully it's pretty easy :)
Storm Reports Map:
Absolut is offline
post #4 of 18 (permalink) Old 10-05-2003, 06:49 PM
I was able to change the bulb on the passenger side without removing anything. I remove the fuse box cover too. It's a good way to change the low beam lite without messing around the engine bay too much.
WiDeFiRE is offline
post #5 of 18 (permalink) Old 10-05-2003, 10:56 PM Thread Starter
sick6.com's Avatar
Replying to Topic 'Just installed my H1 PIAA Hyper White Bulbs :-)'
NOPE.. they are 55 watt . :-) .. i love piaa !!! SOON I WILL GET HID'S ... but for now, these will do..
post #6 of 18 (permalink) Old 10-06-2003, 12:38 AM
lilkoala's Avatar
Send a message via AIM to lilkoala
UNLESS...you're a 6i!! then you don't have to take anything out. just pop the hood, remove the covers, and put the new lights in. peice of cake! :D
lilkoala is offline
post #7 of 18 (permalink) Old 10-06-2003, 08:18 AM
Absolut's Avatar
Yeah.. but who would want a 6i.. i mean really.. :) j/k
Storm Reports Map:
Absolut is offline
post #8 of 18 (permalink) Old 10-06-2003, 09:59 AM Thread Starter
sick6.com's Avatar
Do i own a 6I since i dont have the SPORT PACKAGE.. big deal.. i was going to change the kit on it when one came out at a resonable price anyway .. I still have the same engine !!! 6 cyl MT :-)
post #9 of 18 (permalink) Old 10-10-2003, 09:53 PM
Those lights look awesome..... are they "white" of "blu-ish tint" when you look at them... cause i know the cops in NY are real sticklers about stuff like that..... how much did those cost you?
BoDogg622 is offline
post #10 of 18 (permalink) Old 10-11-2003, 08:36 PM
piece of cake?? you must have child-like hands. things were a b*tch for me to change and I have asian hands. I swear, I was so worried about dropping things left and right. Barely any room to maneuver, it was a frustrating experience. Took about 30 mins per bulb! Easy peasy my @$$.
Kimistry is offline
