All Bulb #'s - Page 26 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 4Likes
post #251 of 258 (permalink) Old 03-27-2016, 08:05 PM
mmceorange's Avatar
Quoted: 1047 Post(s)
Originally Posted by Dennis View Post
i have maz 6 sport 2005 and want to replace the bulbs at the back of the 3 control knobs in centre console,i have fitted 5 new bulbs but only two that light up around knob seem to be working, also what colour goes in what hole.
Not sure if auto climate is same as manual (probably not?) but my auto climate takes three black base and two white base (B,W,B,W,B). I had a lot of trouble with those bulbs.. apparently very easy to damage the filament. Try turning back and forth a few times to clean up the contacts, and try swapping a good bulb into every socket to make sure they all work.
mmceorange is offline
post #252 of 258 (permalink) Old 08-23-2016, 02:38 PM
Did you include the tiny bulbs that light the shifter positions on the console and the cigarette lighter ring?
SubDude007 is offline
post #253 of 258 (permalink) Old 01-27-2017, 06:17 AM
zoomfactor's Avatar
Fog lights are either Type A (integrated) or Type B (lower/bumper) using 55W H3 or H11 globes respectively.
zoomfactor is offline
post #254 of 258 (permalink) Old 02-22-2017, 03:23 PM
jman1200's Avatar
Quoted: 90 Post(s)
Originally Posted by HerronScott View Post
I can give you the Mazda part numbers.
Bulb, air conditioning switch (red - 3) GJ6R-61-C95
Bulb, air conditioning switch (amber -2) GJ6G-61-C95
T4 Type B Neowedge Bulb
They are expensive from the dealer or online dealers.
Scott
I just replaced the light bulb in the Traction Control Switch. Thought I shared this info in this thread which is very helpful even after so many years. I searched and couldn't find it anywhere.
PN GJ6A-66-461
Since this one is a sticky, it would be nice if the list posted in the first page could be updated with the missing/new info.
@Byakuya, maybe something you can help us Gen 1 owners with.
jman1200 is offline
The Following User Says Thank You to jman1200 For This Useful Post:
Byakuya (02-23-2017)
post #255 of 258 (permalink) Old 02-23-2017, 07:23 AM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2882 Post(s)
PN GJ6A-66-461
Done and done Thanks for the info!
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
post #256 of 258 (permalink) Old 01-22-2019, 11:53 AM
wither48's Avatar
Quoted: 38 Post(s)
Hello all, I've been through a couple sets of LED bulbs, and I can't seen to get them to fit the housings of my 6i. I've got the stock headlights, and I've confirmed that h1 bulbs fit, given that I've had to replaced burned bulbs a couple of times. The LEDs just seem to wide to fit through the metal cutout and into the projector. Has anyone found specific brands of h1 LEDs that work?
Sent from my ONEPLUS A5000 using Tapatalk
wither48 is offline
post #257 of 258 (permalink) Old 05-19-2019, 06:01 PM
I had essentially the same question too - has anyone found an H1 LED bulb that can be used in the stock low-beam projector housing and still be able to put the cap back on the back?
I've seen on YouTube (
) where H1 LED's have been installed in the low beams - but not such that the cap to seal out water and dirt could be put back on the housing. Which makes this a non-starter for me - the mess of dirt and salt crusted on the back of the low-beam caps tells me it would take no time driving in winter to fill the housings with a slurry of muck and salt.
rx7racerca is offline
post #258 of 258 (permalink) Old 05-19-2019, 06:13 PM
DJ Raydiate's Avatar
Quoted: 92 Post(s)
I've seen on YouTube (https://www.youtube.com/watch?v=-pFnawPJyX8) where H1 LED's have been installed in the low beams - but not such that the cap to seal out water and dirt could be put back on the housing. Which makes this a non-starter for me - the mess of dirt and salt crusted on the back of the low-beam caps tells me it would take no time driving in winter to fill the housings with a slurry of muck and salt.
There are rubber caps that you can add to the rear of housings to gain a little bit of extra room. You could also build your own by using aluminum hvac duct tape to form a new shape. Place the light into the socket, drill out the cap where it won't hit the new bulb, use the tape to lay a foundation down making sure to leave room around the bulb, and then use jb weld as the main structure for the cap. Retrofitters use either method to get things to fit correctly. If one is good with plastic welding, it could be as simple as building a new dome up with plastic. Hell I've seen people use pvc pipe and caps to do retrofits so if you could think of a way to close it, it would more than likely work lol.
Ray.
2003 6s
DJ Raydiate is offline
